192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. G_Viru
    Jelly Bean Feb 5, 2019
  2. Rotten Egg
    Honeycomb Feb 5, 2019
    elwholo likes this.
  3. SunilAhir
    Cupcake Feb 5, 2019
    SunilAhir , Feb 5, 2019 :
    i update my one plus 5 ,. ut after restart only one plus logo , no next process , what are the issue
  4. animaaryan
    animaaryan , Feb 5, 2019 :
    Phone's Bricked
    Access Restrict
    Go back to Stable
    You'll feel admirable.
    If no avail,
    Send feedback a mail.
    If no solutions,
    Find a store near your location.
    elwholo, RoyxD4, gargyagotra and 4 others like this.
  5. SunilAhir
    Cupcake Feb 5, 2019
  6. Hriday_100
    Froyo Feb 5, 2019
    Hriday_100 , Feb 5, 2019 :
    otg is not working even the dash charge is working perfectly
    i test the otg with other devices but it works perfectly with the others
    so what's the problem?????
    plz help me
  7. SP3NGL3R
    Gingerbread Feb 5, 2019
    SP3NGL3R , Feb 5, 2019 :
    Does it even show up and just not work? Use an empty USB device and tell the 1+ to format it. When I format a device on computer I use exFAT and it works fine as OTG... Test again.
    Doesn't even register? Did you turn OTG on? It times out after 10 minutes. Search settings for OTG. ... Test again
    Hriday100 likes this.
  8. Hriday_100
    Froyo Feb 5, 2019
    its not showing up even i try many times to on-of otg option
  9. O1549386330046
    Cupcake Feb 5, 2019
  10. Icecreamypie
    Ice Cream Sandwich Feb 5, 2019
    Icecreamypie , Feb 5, 2019 :
    Best poem ever
  11. daster_x
    daster_x , Feb 5, 2019 :
    did you enabled it in settings?
  12. 9421214350
    Cupcake Feb 5, 2019
    9421214350 , Feb 5, 2019 :
    what to do for turn off the shuttering sound
  13. Mr_Cyrox
    KitKat Feb 5, 2019
    Mr_Cyrox , Feb 5, 2019 :
    You can't if you live/are in India or other countries that has restrictions on silent shutter sound on camera
  14. prathamesh24
    Froyo Feb 5, 2019
  15. Hriday_100
    Froyo Feb 5, 2019
    yes but didn't work
  16. RaoniZacaron
    Donut Feb 6, 2019
    RaoniZacaron , Feb 6, 2019 :
    Is the op5 Rom already compatible with LCD screen?
    Last times I tried to install the android pie my screen doesn't unlocked after first lock
    So I came back to 8.1 Rom
  17. G_Viru
    Jelly Bean Feb 6, 2019
  18. G_Viru
  19. Tcat007
    Honeycomb Feb 6, 2019
    Tcat007 , Feb 6, 2019 :
    What didn't? OB24 is fine. You can find it at XDA.
  20. G_Viru
