192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. Yag1z
    Gingerbread Feb 21, 2019
    Yag1z , Feb 21, 2019 :
    The problem is that in my country there isn't service center officially
  2. Tcat007
    Honeycomb Feb 21, 2019
    Tcat007 , Feb 21, 2019 :
    You can flash the 1.7gb file in recovery without losing anything. Just clear cache and flash it. But it's good to start from scratch sometimes, just to clear out bugs. You can backup apps and data with OnePlus Switch. You should also back up stuff on internal (music, photos etc) to a pc occasionally.
    kogam22 likes this.
  3. kogam22
    Eclair Feb 21, 2019
    kogam22 , Feb 21, 2019 :
    Yag1z
    The problem is that in my country there isn't service center officially​
    That's . . . a bit unfortunate. Wait. There are experienced guys in the forum. Let's wait for their reply.
  4. Yag1z
    I know, I did already that like two weeks ago
  5. Yag1z
    Yes, let's wait for them. I'll try it in couple of minutes again then I won't try again. I'll wait for next update.
    kogam22 likes this.
  6. Mhtnr
    Donut Feb 21, 2019
  7. Tcat007
    Factory reset? Always check md5 of big files.
    5T (ob24) Md5: 19e06a4aae5d3754ced2ca3a36fea328
    5 (ob26) Md5: 93de610fcf4da661a1dfa00a27b0a478
    kogam22 likes this.
  8. Yashvendra_Singh_Raghav
    Ice Cream Sandwich Feb 21, 2019
    Yashvendra_Singh_Raghav , Feb 21, 2019 :
    update has arrived but ... why one plus laboratory feature was missing..as obt 26/24 on 5/5t is very similar to obt of 6/6t
  9. Mr_Cyrox
    KitKat Feb 21, 2019
    Mr_Cyrox , Feb 21, 2019 :
    Did OTA from old OB 26 to new OB 26 and no failing here :rolleyes:
  10. lucky_ameta
    lucky_ameta , Feb 21, 2019 :
    Not a big update but anyways hopefully gaming mode will be fixed as it was totally messed up
  11. paulomodesto
    Jelly Bean Feb 21, 2019
    paulomodesto , Feb 21, 2019 :
    It's not stuck, it stays like that for 2 or 3 minutes, happened to me too.
    Over all process takes more time that it used to be, maybe they slow down the entire process so nothing get corrupted not allowing to devices get bricked.
  12. Xetmes
    Xetmes , Feb 21, 2019 :
    My 5T stuck on "checking for updates", I got notification about new update, opened update center and nothing happen. :)
    OK, downloading now...
    OK, went fine ;)
  13. SoumyaMahunt
  14. umeraiyubi
  15. Klimo
    Froyo Feb 21, 2019
    Klimo , Feb 21, 2019 :
    with blue spark 9.91 TWRP you do not need to delete the compatible.zip anymore. First flash magisk uninstall.zip, clear cache / dalvic, install beta 24/26, install magisk 18.1 zip, delete cache / dalvic, reboot, done ....
  16. B1513574149183
    Eclair Feb 22, 2019
  17. Braedach
    Eclair Feb 22, 2019
  18. delucaserick
    Gingerbread Feb 22, 2019
  19. O1542895751445
    Eclair Feb 22, 2019
  20. R1512274214831
    R1512274214831 , Feb 22, 2019 :
    go to recovery clear cache from there and try to update package from there it will work for 5t
