192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. L1528074234618
    Froyo Feb 22, 2019
    L1528074234618 , Feb 22, 2019 :
    im on 23 beta lol
  2. L1528074234618
    Froyo Feb 22, 2019
  3. toastytoast1234
    Marshmallow Feb 22, 2019
    The1Lion likes this.
  4. C1528541102683
    Cupcake Feb 22, 2019
  5. Cervantes
    Lollipop Moderator Feb 22, 2019
  6. Cervantes
    Cervantes , Feb 22, 2019 :
    Hi
    The update thread is a thread of questions and/or commentary
    Please, read the first and second post
    Thread merged
  7. Tcat007
    Honeycomb Feb 22, 2019
    Tcat007 , Feb 22, 2019 :
    That's why. Need 9.91 for pie.
  8. L1528074234618
    Froyo Feb 22, 2019
  9. Tcat007
    Official update is in support-software section here.
  10. MarcioReis87
    Ice Cream Sandwich Feb 23, 2019
  11. MatheusLima1103
    Cupcake Feb 23, 2019
    MatheusLima1103 , Feb 23, 2019 :
    There s a tutorial video to resolve that error? Thanks
  12. L1528074234618
    Froyo Feb 23, 2019
    L1528074234618 , Feb 23, 2019 :
    bro are u having erorr 7 too?
  13. MatheusLima1103
    Yes. It lowers everything but does not install and is downloading "infinitely"
  14. pratik_i_am
    pratik_i_am , Feb 23, 2019 :
    Got this ota yesterday on op5... Update failed 3 times... Tried local upgrade but failed... Any solution?
    also tried upgrading in recovery but nothing happens
    Update:- Clearing cache solved issue
  15. I1530254299940
    Eclair Feb 23, 2019
    I1530254299940 , Feb 23, 2019 :
    better do a factory reset and local upgrade.
  16. gargyagotra
    Gingerbread Feb 23, 2019
    gargyagotra , Feb 23, 2019 :
    I don't agree here..BETA program is still best. Problem is that many novices have joined the Open BETA who don't understand the basics of software development and are just looking to try out new features without contributing anything from their side like logs or raising bugs.
    Now to answer your question, what I assume is that you installed OB24 earlier when it was first released and everything went fine...however for few users, the same OB24 was causing bootloops. So one plus paused the update as mentioned in the second post of this thread.
    On Feb 20, they first updated the Support website with the complete 1.7GB package and then based on different states of user phone, they started rolling out OTA with different file sizes to bring all devices to parity with 1.7GB file. That meant that some users like you recieved 200 MB files while some recieved 300MB files etc. Since your system is already on OB24, the update process for this OTA patch is slightly different as the Updater app was never intended to handle this situation where it will install the patch of a version that already exists on user device. Hence, the reason of that extra TIP which is being shown with the new OTA. I am sure it's just a one time thing and from OB 25/27 things will resume to be normal again.
    Now, since folks were getting different file sizes in OTAs some people thought that it's better to just download the complete 1.7GB package from the support website and being their device to a state where one plus wants you to be before releasing the next BETA. This was just a safety precaution by users who wanted to eradicate any glitches that sometime come when you merge patches on an active device and therefore doing a full package installs updates the device completely with no doubt whether the OTA patch worked or not.
    One plus could have disclosed more information on what went wrong, but this thread will not be the correct destination for that analysis. I am sure that you might see some details on the issue causes in one of their weekly updates or a separate thread on the same.
    Hope it clarifies!
    Disclaimer: all the above is just my assumptions and I am no way associated with OP Dev team
    AnimatedKiller and DavidMdz like this.
  17. gargyagotra
    Download the file from support website...then go-to recovery and flash it....
  18. pratik_i_am
    yeah i hv downloaded from website but in recovery update fails... nothing happens
  19. gargyagotra
    Have you compared the MD5 hash of the file with the one available on website to make sure that downloaded file is indeed complete and not corrupted during download?
    If not, do that....the only reason I can think of is that the package is corrupted...and you will have to download it again.
    Will suggest to use MD5 check for large packages..there is a reason they are displayed on support website .
  20. angeloalban02
    Froyo Feb 23, 2019
    angeloalban02 , Feb 23, 2019 :
    How much does this update weigh? Because I made a first attempt and it came out 339 MB and it gave me an installation error, now that I rebooted the phone, I get a weight of 1774 MB ... Should I wait or should I go for the update immediately???
