192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. Pranav_Chopra47
    Donut Feb 23, 2019
    Pranav_Chopra47 , Feb 23, 2019 :
    yes I checked the md5 hash the file isn't corrupted and I was on beta before
  2. MJ_Vikram
    KitKat Feb 23, 2019
    MJ_Vikram , Feb 23, 2019 :
    it's not County specific.. every one will get at same time..
  3. An.I.Am
    Jelly Bean Moderator Feb 23, 2019
    An.I.Am , Feb 23, 2019 :
    ¯\_(ツ)_/¯
    We don't know, please have a look at this thread about updates.
  4. Prabhucharan
    Donut Feb 23, 2019
    Prabhucharan , Feb 23, 2019 :
    i did not receive it yet
  5. PokiX
    Jelly Bean Feb 23, 2019
    PokiX , Feb 23, 2019 :
    humm weird does it fail before even flashing or during process?
    the updater script checks for:
    Good image wrt to the real model
    Vendor partition exists. It should if you were on Pie before.
    What is the *exact* message.
  6. pratik_i_am
    Cupcake Feb 23, 2019
    pratik_i_am , Feb 23, 2019 :
    for all those who r facing issue while updating to ob26/24 here is the solution...
    Download ROM zip from OnePlus website
    Go into recovery
    Clear Cache first
    Update zip
    Again Clear cache
    Reboot
  7. SP3NGL3R
    Gingerbread Feb 23, 2019
  8. MJ_Vikram
    KitKat Feb 23, 2019
    are you on beta ? check first post for more details..
  9. pratik_i_am
    clear cache and upgrade in recovery
  10. syedhabib2582.ss
  11. C1523866945809
    C1523866945809 , Feb 23, 2019 :
    Since last night this pop up for new update is visible to me but when I open it nothing happened.pls help.arigatto.
  12. Dereck Edwards
    Donut Feb 23, 2019
    Dereck Edwards , Feb 23, 2019 :
    the new update for 5t show there is and update but you are unable to get the update for checking update process it remains with no change to download
  13. Carman00
  14. Moin2200
    KitKat Feb 23, 2019
    Moin2200 , Feb 23, 2019 :
    I mean it shouldn't really matter. It's just confused about an update and once it realizes there is nothing then leave it.
  15. B_Wrath
    Marshmallow Feb 23, 2019
  16. Tcat007
    Honeycomb Feb 23, 2019
    Tcat007 , Feb 23, 2019 :
    Beta is for people that know what they're doing. Why so many newbies came to beta, it's really not much different from stable.
    Always best to download file (not through ota), check md5 (if you don't know how to do that, at least make sure the zip opens). File should be 1.7gb+
    Backup with titanium if you're rooted, if not use OnePlus Switch (doesn't take long at all). Save important files on internal memory to cloud or PC.
    Clear cache in recovery, flash zip in recovery (system, or TWRP if you use that). You won't lose anything.
    If something falls, do a factory reset (wipe data), and previous ROM flash. You'll lose stuff, but you have it backed up. Takes 15-30 minutes to do a clean flash and get back to where you were.
    You can learn a lot reading support section and xda threads. None of the OnePlus updates have had bugs, I've flashed all stable and beta with no issues at all. Camera has improved a lot since Oreo. Adaptive brightness has improved (although dark environments could be improved). Battery is the same (excellent).
    If you have bugs, you don't know what your doing, or your phone is dieing, or you live in India and want your camera silent.
  17. Dereck Edwards
    Donut Feb 23, 2019
    Neva had issues before with the update the fact I have to go through all that says something is wrong. Each time I had an update I click and download simply
  18. PokiX
    I would suggest helpers to stop helping on how to install an OOS beta image. It doesn't help anyone in the long run...
    gargyagotra likes this.
  19. C1523866945809
  20. LLcdPH
    Eclair Feb 23, 2019
    LLcdPH , Feb 23, 2019 :
    The Beta 24 also fails on my 5T and continued trying to download and install.
    L1528074234618 likes this.
