192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. Cervantes
    Lollipop Moderator Feb 24, 2019
    Cervantes , Feb 24, 2019 :
    What update, what version of oxygen do you have?
  2. sahelmakrani
    Cupcake Feb 24, 2019
  3. Cervantes
  4. sahelmakrani
  5. Cervantes
    Hi
    The beta thread is a thread of questions and/or commentary
    Please, read the first and second post
    Thread merged
  6. G_dharshan_coorg_Uuxy
  7. sahelmakrani
  8. Cervantes
    Hi
    Thread merged
  9. crank2
    crank2 , Feb 24, 2019 :
    Bluetooth still not working properly.
    Play command not working and equaliser via Bluetooth not working.
  10. PokiX
    Jelly Bean Feb 24, 2019
    PokiX , Feb 24, 2019 :
    Yes true, there's sideload to try.
    Curious, did you manage?
  11. PokiX
    "Not working" doesn't say much.
  12. PokiX
    That's a bug, expected with a beta.
    There are a lot of ways to investigate (adb logcat for example) or you can try manually installing from the recovery.
    Or wait for a release in Stable.
  13. Pranav_Chopra47
    Froyo Feb 24, 2019
    Pranav_Chopra47 , Feb 24, 2019 :
    yes adb sideload was successful and on 5t I downloaded the full zip from OnePlus website and flashed it from recovery it was successful maybe there was some problem in my op5 so I also formatted it
  14. PokiX
    Search the forum it has been covered. If you can't find, contact support.
    All your data will be secured and as such unreachable and lost, just to warn you.
  15. crank2
    I have bug reported it the last 2 beta's and that's why I write what I do, nothing has changed.
    everything works perfect in last 8 beta.
  16. PokiX
    ok good.
    But wait, all zips you tried were full zip right? (1.7GB around)
    Or was one of your previous tries an incremental zip (like under 500MB) ?
  17. Pranav_Chopra47
    Froyo Feb 24, 2019
    yes all zips were whole system zips (1.7-1.8 GB)
    I tried incremental update only in system update (staying on the screen) and then reboot to upgrade but it was failed in both OnePlus 5 and 5t "installation error"
  18. ManojkrishnaS
    Donut Feb 24, 2019
    ManojkrishnaS , Feb 24, 2019 :
    Make digital well-being work on op5... huawei has made their own digital well-being setup inside their settings on android pie.. why not one plus ... ? its a great feature and many would lyk to have it
    Harry d best likes this.
  19. luis_s_guerreiro
    Donut Feb 24, 2019
    luis_s_guerreiro , Feb 24, 2019 :
    Has anyone managed to do the latest update of Oneplus 5?
    I download it but then I could not install the update.
  20. Cervantes
