192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. gargyagotra
    Gingerbread Feb 24, 2019
    gargyagotra , Feb 24, 2019 :
    Same here...never had any issues because I make it a point to READ first...and the result is a flawless device performing exactly when I bought it...
    People randomly flash anything , don't follow provided instructions and then expect that one plus will assign a personal assistant to troubleshoot their issues...
    Btw, I have tried to explain why is this update different from others and if anyone is interested, they can scroll back a few pages and try to understand why this update process is different from the usual ones and why folks are getting different file sizes in OTA's.
    zer0se7en likes this.
  2. Icecreamypie
    Ice Cream Sandwich Feb 24, 2019
    Icecreamypie , Feb 24, 2019 :
    Yes you were lucky
    Everytime i root
    My phone resets itself :(
  3. Icecreamypie
    But i think thats good
    So i can delete junk files too
  4. zer0se7en
    zer0se7en , Feb 24, 2019 :
    I ain't. because I have done it on every update from Stable or Open Beta. Even downgrarding. If you were near me, I would help you by showing you how it's done. Been doing all these flashing stuff since Nexus 5 and OnePlus One.
  5. A1514626101322
    Donut Feb 24, 2019
    A1514626101322 , Feb 24, 2019 :
    Hi guys I'm still in beta 23 on my OP5T. I get the update and (even following the guide that says not to exit the update app) the phone downloads the update but when I press "reboot to upgrate" it doesn't work. I also tried to locally upgrade it as the guide says and installing it from recovery but with the same result. What should I do?
  6. gargyagotra
    Try downloading the 1.7GB file from their website and flash it through recovery...only if you know what you are doing
  7. A1514626101322
    Donut Feb 24, 2019
    Thanks for the advice, eventually, what is the procedure to safely go back to the stable version of oxygen os?
  8. luis_s_guerreiro
    Donut Feb 24, 2019
    luis_s_guerreiro , Feb 24, 2019 :
    Cervantes
    What update, what version of oxygen do you have?​
    The version I have is OP5_O2_BETA_25 .
    I was trying to install the version OP5_O2_BETA_26.
  9. PEU777
    Cupcake Feb 24, 2019
    PEU777 , Feb 24, 2019 :
    my one plus 5t automatically switch off and then automatically switch on pls help me.
  10. J1551032812782
  11. Cervantes
    Lollipop Moderator Feb 24, 2019
    Cervantes , Feb 24, 2019 :
    Hi
    The beta thread is a thread of questions and/or commentary
    Please, read the first and second post
    Thread merged
  12. jonnypjonny
    jonnypjonny , Feb 24, 2019 :
    after updating lost the hability to detect 5ghz WiFi networks. tested in iPhones and other droids and both detect. not my oneplus5.....
  13. SaiViswanath1999
    SaiViswanath1999 , Feb 24, 2019 :
    CAN'T ABLE TO INSTALL PACKAGE
    I got a serious problem in installing package. Now I'm in beta 25 I downloaded updates via settings. After completing download it's not showing reboot for install. Then after sometime it showed error. Again I tried to download before it shown 300mb not it's 1.7gb I downloaded again it didn't show reboot to install after sometime it shows error again. Then I tried manually by installing packing in this also I can't able to install packages. I don't know why.
  14. SaiViswanath1999
  15. PokiX
    Jelly Bean Feb 24, 2019
    PokiX , Feb 24, 2019 :
    An application that crashes is buggy. period..
  16. paulomodesto
    Ice Cream Sandwich Feb 25, 2019
    paulomodesto , Feb 25, 2019 :
    There's a lot of lag sometimes.
    Animation and scrolling turns not fluid at all, there's is like a shake, even scrolling in the drawer applications.
    It's something that is here since first Pie beta, but it's really worse in this latest beta.
    That and the fingerprint sensor that sometimes stops working it's making me tired of this phone, it was working so good before the Android Pie.
  17. mehulgupta462
    Honeycomb Feb 25, 2019
  18. ManojkrishnaS
    Donut Feb 25, 2019
    ManojkrishnaS , Feb 25, 2019 :
    i tried installing it manually... its installed and it's not showing in my app drawer or in my settings ? Can u give me the way to install it and make it work?
  19. Dextro_619
    Dextro_619 , Feb 25, 2019 :
    I am on beta 26 since 4 days and it's working flawlessly .. didn't faced any lag or something
  20. mehulgupta462
    mehulgupta462 , Feb 25, 2019 :
    thanks for the reply
