192
OxygenOS Open Beta 26 for the OnePlus 5 and Open Beta 24 for OnePlus 5T
  1. mehulgupta462
    Honeycomb Feb 26, 2019
    mehulgupta462 , Feb 26, 2019 :
    you can reduce variation by not using phone in the areas where the signal strength is weak
  2. MJ_Vikram
    KitKat Feb 26, 2019
    MJ_Vikram , Feb 26, 2019 :
    it's in limit only so no need to worry..
    Everley and N1513510080942 like this.
  3. MJ_Vikram
    KitKat Feb 26, 2019
    download the open beta 26 and flash it through recovery .. it worked for me..
    Jituraj06 likes this.
  4. MJ_Vikram
    KitKat Feb 26, 2019
    read the 2nd post they have given solution for this.. you just need to download and flash it from recovery..
  5. MJ_Vikram
    KitKat Feb 26, 2019
  6. MJ_Vikram
    KitKat Feb 26, 2019
  7. MJ_Vikram
    KitKat Feb 26, 2019
    it depends on usage so no one comment on this..
  8. Ry mahesh
    Donut Feb 26, 2019
    Ry mahesh , Feb 26, 2019 :
    can i follow one of the two steps at this stage?
  9. Ry mahesh
    Donut Feb 26, 2019
    i tried installing in both ways..... nothing worked for me...!
  10. Ry mahesh
    Donut Feb 26, 2019
    none of them worked for me
  11. Ry mahesh
    Donut Feb 26, 2019
  12. Dwitikrushna
    Cupcake Feb 26, 2019
    Ry mahesh likes this.
  13. MJ_Vikram
    KitKat Feb 26, 2019
  14. Ry mahesh
    Donut Feb 26, 2019
    installation failed....i tried
  15. MJ_Vikram
    KitKat Feb 26, 2019
  16. sthita72
    Donut Feb 26, 2019
    sthita72 , Feb 26, 2019 :
    Try downloading the update in a system and flash it from recovery after the zip file is moved to your mobile
  17. PokiX
    Jelly Bean Feb 26, 2019
    PokiX , Feb 26, 2019 :
    By not putting it next to the ear in "hidden" places. Like with ANY phone! House, car, tunnel,..
  18. paulomodesto
    Ice Cream Sandwich Feb 26, 2019
    paulomodesto , Feb 26, 2019 :
    Once again, today I wake up in the morning and when I wake up my OP5T from a 8 hours nigh deep sleeping, there was Lag everywhere, the scrolling and the animations so bad, Damm!
    Restarted and it goes like nothing happened...
  19. PokiX
    Why should the behavior change if nothing changed?
    You are on a beta, you need to investigate a bit, we can't help you remotely.
    Tried factory reset?
  20. paulomodesto
    PokiX
    Tried factory reset?​
    Factory reset is the worst I can do, there is no backup to apps data.
    So it's bad, every time I have a problem the solution is reset, it turns worst when it not solves the problem.
    That's the only thing I hate on Android!
    Go to see if they can fix this problem, because it's not only me, I'm thinking about on exchange brand to Xiaomi MI9.
    Let's wait some more time, but I'm not happy now!
