80
OxygenOS Open Beta 27 for the OnePlus 5 and Open Beta 25 for OnePlus 5T
  1. Oneplus1706 Donut Feb 28, 2019
    Ravi BINAVAT likes this.
  2. yetursri Cupcake Feb 28, 2019
    yetursri, Feb 28, 2019 :
    i hv the same problem. no solution yet.
  3. W1519983129267 Donut Mar 1, 2019
    W1519983129267, Mar 1, 2019 :
    Having trouble upgrading this update. every time it downloads the update, when I try to reboot, it goes back and says downloading. attached 2 screen shots. 1 is my phone status, 2 is the screenshot of the page.
  4. Ratnesh Dubey Cupcake Mar 1, 2019
    Ratnesh Dubey, Mar 1, 2019 :
    Hey guyz, Is anyone facing auto brightness issue? My OnePlus 5T is on 40% brightness even in pitch dark conditions. This happened after the latest beta build update for OnePlus 5T.
  5. C1544629534000 Donut Mar 1, 2019
  6. shmalay007 Eclair Mar 1, 2019
    shmalay007, Mar 1, 2019 :
    after this update my phone dont discover 5ghz wifi signal. is this problem only with me or with all?
  7. Tcat007 Honeycomb Mar 1, 2019
    Tcat007, Mar 1, 2019 :
    You do know there's a download section here. It's under "support-software upgrade". Download latest at anytime without ota issues.
    https://www.oneplus.com/support/softwareupgrade/details?code=7
    Ravi BINAVAT and Ofo like this.
  8. Ofo Donut Mar 1, 2019
  9. skirhami Cupcake Mar 1, 2019
    skirhami, Mar 1, 2019 :
    Thanks! That works! I was unaware of that feature.
  10. G1510887316124 Gingerbread Mar 1, 2019
    G1510887316124, Mar 1, 2019 :
    Is there any solution for screen freezing bug from 0b24 update for 5T.It's really very disturbing and bothering .already mailed to oneplus 5t team regarding this.
  11. Jitesh Saitawadekar KitKat Mar 1, 2019
    Jitesh Saitawadekar, Mar 1, 2019 :
    Just use un brick tool method see if that help or else you can go to service center.
  12. Rakesh_Kumar_T_ Jelly Bean Mar 1, 2019
  13. Jitesh Saitawadekar KitKat Mar 1, 2019
    If your concept is so clear what does "it can be done through app update" means?? And if I am right you mean to say if there is major changes then only update need to be pushed ??
  14. PokiX Jelly Bean Mar 1, 2019
  15. Mr_Cyrox KitKat Mar 1, 2019
    Mr_Cyrox, Mar 1, 2019 :
    Good that I'm not the only one that noticed it :rolleyes:
  16. Mr_Cyrox KitKat Mar 1, 2019
  17. Mr_Cyrox KitKat Mar 1, 2019
    Most likely it won't be solved as it's a requirement in your country (I assume you live in India)
    Ravi BINAVAT and HalCapone like this.
  18. Mr_Cyrox KitKat Mar 1, 2019
    OnePlus isn't good at explaining at what they change for example
    • General bug fixes and system stability improvements
    • Enhanced [enter feature here]
    What and how are we supposed to test?
    Ravi BINAVAT, jay5t and PokiX like this.
  19. smitbhagat Honeycomb Mar 1, 2019
    smitbhagat, Mar 1, 2019 :
    Yes, basically when you turn on the game mode on, you could not use your keys right? so now they have given one more tap to get out of that mode without opening the notification bar,try it out
  20. HalCapone Honeycomb Mar 1, 2019
    HalCapone, Mar 1, 2019 :
    How many more time do you have to explain this to people lol.
