116
OxygenOS Open Beta 28 for the OnePlus 5 and Open Beta 26 for OnePlus 5T
  1. M1512051625379
    Donut Mar 13, 2019
    Ravi BINAVAT likes this.
  2. Chiran_OP5
    Honeycomb Mar 13, 2019
    Chiran_OP5 , Mar 13, 2019 :
    It's working well on my end.
  3. Chiran_OP5
    same on my device as well.
  4. anksjdhv
    Froyo Mar 13, 2019
    anksjdhv , Mar 13, 2019 :
    it was working for me till beta 26 for OP5 too.. I tried reinstalling the apk from apkmirror but it's of no use..
  5. Chiran_OP5
    I see.
    Battery is draining fast on my end.
  6. Aziz_Amin_Oneplus
    Jelly Bean Mar 13, 2019
    Aziz_Amin_Oneplus , Mar 13, 2019 :
    Not mine I am in 75% and I have 1:30 SOT, wifi, location and mobile data always on.
    Ravi BINAVAT and Chiran_OP5 like this.
  7. Chiran_OP5
    Did you do clean update?
    I came from open beta 27.
  8. Aziz_Amin_Oneplus
    I came from 9.0.4 update, it's same battery level and have done factory reset without internal storage.
  9. Tcat007
    Tcat007 , Mar 13, 2019 :
    All good dirty flash ob25 to ob26. Battery 5.5 hrs sot with 33% left. Dark messaging works fine. Rooted and substratum themes work fine. March security! Anyone with issues should clean flash through recovery.
    Ravi BINAVAT and Rakshit_Patil like this.
  10. Aziz_Amin_Oneplus
    Yup everything is fine with day end it will be same battery life like before with 2 days and 7-8 hours of screen on time, good update OnePlus.
  11. P1552501936053
    Donut Mar 13, 2019
    P1552501936053 , Mar 13, 2019 :
    how will I get this beta version update??
  12. Aziz_Amin_Oneplus
    Through system update if you are using stable version.
  13. P1552501936053
    Donut Mar 13, 2019
  14. P1552501936053
    Donut Mar 13, 2019
    there is no update in system update
  15. Aziz_Amin_Oneplus
    Which update version you are using check in about phone and post a screenshot?
  16. P1552501936053
    Donut Mar 13, 2019
    this one
  17. W1519210452242
    Cupcake Mar 13, 2019
  18. Aziz_Amin_Oneplus
    You are on Stable version, you need to update on Beta version by downloading the file, I will warn you this is beta update not stable and full of bugs so if you want to install and if you find any problems then do not complain, correct yourself, what you want?
  19. P1552501936053
    Donut Mar 13, 2019
  20. JYanz
    Gingerbread Mar 13, 2019
    JYanz , Mar 13, 2019 :
    I dare you to type *#008# and see the magic. it's works for me .
