129
OxygenOS Open Beta 29 for the OnePlus 5 and Open Beta 27 for OnePlus 5T
  1. Nick 59
    Marshmallow Apr 14, 2019
    Nick 59 , Apr 14, 2019 :
    This is the BETA thread.
    Updates are released when they are ready.
  2. jas22g
    Donut Apr 14, 2019
  3. Mr_Cyrox
    KitKat Apr 14, 2019
  4. G_Daniel_Piña_BJCv
    Cupcake Apr 14, 2019
  5. sapkotasriyas
    Gingerbread Apr 14, 2019
    sapkotasriyas , Apr 14, 2019 :
    after you take a screenshot, click on expanded screenshot
    G_Daniel_Piña_BJCv likes this.
  6. G_Daniel_Piña_BJCv
    G_Daniel_Piña_BJCv , Apr 14, 2019 :
    Oh, You are right! I must have been trying it con scenarios where it couldn't been done. My fault lol
  7. benm7896
    Froyo Apr 14, 2019
  8. G_Parthesh_Jadhav_TNSs
  9. Mr_Cyrox
    KitKat Apr 14, 2019
    Mr_Cyrox , Apr 14, 2019 :
    Great things can't be rushed
  10. NUCM_DH
    NUCM_DH , Apr 14, 2019 :
    you mean weather and op switch
  11. Mr_Cyrox
    KitKat Apr 14, 2019
    Depends on which part you consider great
  12. Jairo_666
    Donut Apr 14, 2019
    Jairo_666 , Apr 14, 2019 :
    Battery drains pretty faster on last open beta, but the most annoying thing I have all over the pie's update is the lag while open apps, since pie it happens from time to time but it's really frustrating.
  13. paulomodesto
    Ice Cream Sandwich Apr 14, 2019
    paulomodesto , Apr 14, 2019 :
    And with time will be worst, if not you will not buy another OnePlus Smartphone.
  14. Mr_Cyrox
    KitKat Apr 14, 2019
    Everything fine on my end...
    Maybe it's one of your apps?
    Have you looked at the pinned battery threads?
    Searched for lag solutions as there are plenty?
  15. Jairo_666
    Donut Apr 15, 2019
    Jairo_666 , Apr 15, 2019 :
    Everything was fine for me till pie. Before that, my phone's performance was so fast, smooth and the battery used to last till the end of the day (was on beta always). I've tried rebooting the system and it fixs the problem for three or four days, then it appears again. In every new beta update I think it will fix this issue, but till now it did not. I'll try by a factory reset. Do you think it could help?
  16. Mr_Cyrox
    KitKat Apr 15, 2019
    Mr_Cyrox , Apr 15, 2019 :
    If you didn't factory reset after the Pie update, yes it most likely will help...
    It's always recommended to do a factory reset after a major system update...
    Also don't restore things with Google backup...
    Set your phone as new
  17. G_Parthesh_Jadhav_TNSs
    Gingerbread Apr 15, 2019
  18. paulomodesto
    Ice Cream Sandwich Apr 15, 2019
    paulomodesto , Apr 15, 2019 :
    One more day without a new beta, and believe me i need it.
    This night in about 5 Hours in standby the battery dropped from 100 to 85%.
    A reboot fix it for about a couple of days until it start the drain again.
    Never happened until this beta...
    Let´s wait for a magic beta...
    For now to me it's the only complain i have, the battery life.
  19. Jairo_666
    Donut Apr 15, 2019
    Ok, man. I will do so! thanks for the advice...
  20. Rotten Egg
    Honeycomb Apr 15, 2019
    Rotten Egg , Apr 15, 2019 :
    True....a magic beta needed.
