129
OxygenOS Open Beta 29 for the OnePlus 5 and Open Beta 27 for OnePlus 5T
  1. 4sheesh
    Honeycomb Mar 25, 2019
    #81
  2. Tcat007
    Tcat007 , Mar 25, 2019 :
    Just got mine in USA. Doesn't look or feel any different, but I use Nova launcher, so UI changes won't be there. No issues with dirty flash.
    #82
  3. M1512051625379
    Donut Mar 25, 2019
    #83
  4. I_am_Batman
    KitKat Mar 25, 2019
    I_am_Batman , Mar 25, 2019 :
    Wow. That weather must really be buggy. it's like 5-6 times they've changed something to the weather cause if the bugs.
    #84
    jayr___, Dhruvit Jain and xnutzii like this.
  5. Mr_Cyrox
    KitKat Mar 25, 2019
    Mr_Cyrox , Mar 25, 2019 :
    To enable/disable Pie gestures on OnePlus 5 and below:
    Code:
    Note! You must have ADB installed on your PC!
    And your device must be running Pie!
    1. Go to Settings > Buttons & Gestures > Buttons > Enable On-Screen navigation bar (This will get replaced with Pill navigation gestures after the process).
    2. Turn on USB Debugging from developer options and connect your phone to your pc.
    3. [PC] Open Windows Command Prompt or Windows PowerShell.
    4. Run this command:
    Code:
    adb shell settings put secure swipe_up_to_switch_apps_enabled 1
    To disable/restore:
    Code:
    adb shell settings put secure swipe_up_to_switch_apps_enabled 0
    #85
  6. Mario Consalvo
    Donut Mar 25, 2019
    Mario Consalvo , Mar 25, 2019 :
    With this OB screenshot editor is amazing, but I can't find the option to do extended screenshot, anyone can help me to find it ?
    #86
    Dhruvit Jain likes this.
  7. xnutzii
    Lollipop Mar 25, 2019
    xnutzii , Mar 25, 2019 :
    well on my 5T (beta 25) and the weather app crashes whenever it wants and the gps doesn't work. maybe it'll change after the update
    #87
    Chuck_James likes this.
  8. xnutzii
    it's only available in some screens, after you've taken the screenshot, it'll show "extended screenshot" right below the screenshot you took in the small window.
    #88
  9. redlinecoatings
    Ice Cream Sandwich Mar 25, 2019
    redlinecoatings , Mar 25, 2019 :
    Many mid range and other phones have a "night mode" and guess what? They suck. Terribly. Even the night mode on the 6T/6 is brutal. The only phone that is ok is the pixel. So you want them to implement their crappy software that isn't working on the newer phones to these older ones and expect what? All you will end up with is more complaining on here and I think there is enough of that already.
    I can take a better shot in low light on manual mode with the stock camera than someone with a pixel and night mode. And it may take me 2 seconds more to set up.
    It's very easy to make presets in manual mode, then there is very minimal tweaking when it's time to take your photo.
    #89
  10. asish022
    Gingerbread Mar 25, 2019
    #90
  11. Tcat007
    Couldn't find screen shot editor, then realized gallery has to be unabled...lol Oh well, I just use Photos and Photo Editor, hate gallery.
    #91
  12. Sid_Ck
    Sid_Ck , Mar 25, 2019 :
    OnePlus is on fire with quick updates from the past few months for 5 & 5T .. Thx OnePlus
    #92
    Rotten Egg likes this.
  13. Klimo
    Froyo Mar 25, 2019
    #93
  14. ChuckJames
    #94
  15. ChuckJames
    ChuckJames , Mar 25, 2019 :
    it s not working in every app
    #95
  16. Aziz_Amin_Oneplus
    Jelly Bean Mar 25, 2019
    Aziz_Amin_Oneplus , Mar 25, 2019 :
    At least we would hope for a better night scape capture rather than getting Oil Paint effect all over it, if they try reducing that too that would be very good, so why are they not doing it?
    #96
    rasulkhan7 likes this.
  17. rinku2bapi
    rinku2bapi , Mar 25, 2019 :
    plz add
    1. hide app option
    2.audio tuner for Bluetooth
    3.nightscape if possible
    4.better Bluetooth connectivity. ..
    5.Fm radio
    some times during flipping or rotating mobile side by side Bluetooth connection disconnect temporarily....hope will get next beta..
    #97
    bpaterson and rasulkhan7 like this.
  18. giuseppeks
    Eclair Mar 25, 2019
  19. redlinecoatings
    The camera software needs some refinement there's no doubt about that. Why they aren't doing it I have no idea.
    But night modes are a gimmick and produce poor results at best. I want them to work on their post processing rather than introduce more problems with shoddy night modes.
    #99
  20. Shiv.Maneyapanda
    Cupcake Mar 25, 2019
    Shiv.Maneyapanda , Mar 25, 2019 :
    I know. It's a seperate app but they send OS updates for improvements. it's just mind boggling. I think they've forgotten that the camera exists on these devices. No improvements whatsoever.
