212
OxygenOS Open Beta 3 (7.1.1) for OnePlus 3T
  1. sujaymodiii
    Ice Cream Sandwich Mar 1, 2017
    #81
    Versed likes this.
  2. katheria09
    katheria09 , Mar 1, 2017 :
    if you downloaded the file from system updater then let the phone reboot after it downloads the file it will automatically take you to twrp recovery and will install the ota .
    #82
  3. arvindbadri
    Eclair Mar 1, 2017
    arvindbadri , Mar 1, 2017 :
    Fingers crossed! :D
    #83
    katheria09 likes this.
  4. pegasuz
    Cupcake Mar 1, 2017
    pegasuz , Mar 1, 2017 :
    Can anyone verify this?
    This concerns not having any audio meta data (song, artist) when streaming through Bluetooth.
    #84
    reylimo likes this.
  5. Blue_Tree
    Eclair Mar 1, 2017
    #85
    viktamvr likes this.
  6. Master_TC
    Jelly Bean Mar 1, 2017
    Master_TC , Mar 1, 2017 :
    Yes, one bloat less.
    #86
  7. arvindbadri
    Eclair Mar 1, 2017
    #87
  8. katheria09
    buttons lights are on or off ??
    #88
  9. arvindbadri
    Eclair Mar 1, 2017
    #89
  10. katheria09
    then its okay . If you buttons lights keep on then you are stuck . If the are off then no issue ,give it some time .
    #90
  11. himanshudhoopia
    Honeycomb Mar 1, 2017
    #91
  12. jstiggie
    jstiggie , Mar 1, 2017 :
    Are you dumb?
    #92
    wahyupolos and jerrymilton like this.
  13. jstiggie
    #93
  14. arvindbadri
    Eclair Mar 1, 2017
    It worked, thank the heavens. I was hyperventilating so badly while the bootanimation went round and round and round, as if the valence electrons in the Oxygen shell were mocking my android skills, but it is done, my phone is exactly the way it was before I updated, except with brand-spanking-new software. Many thanks to @Shekhar.borntofly
    #94
  15. jstiggie
    #95
    Engrbadar likes this.
  16. katheria09
    Mention not . Happy to help :)
    #96
  17. Milind.Deval
    Gingerbread Mar 1, 2017
    #97
  18. BaaDNwZ
    BaaDNwZ , Mar 1, 2017 :
    It's not normal. Losing 1%-2% per 8 hrs sleeping it's normal.
    Just why da f*q are you posting it here? it's should be a helpfull thread not ss posting :|
    Avoid using old TWRP versions.
    clean flash the rom, nothing will crash
    #98
  19. mariusc_alexandru
    Froyo Mar 1, 2017
    #99
    wahyupolos, snowcat98 and otto2 like this.
  20. DimitrisCSD
    Froyo Mar 1, 2017
    DimitrisCSD , Mar 1, 2017 :
    My biggest hope was the alert slider being fixed (allow 0 volume in DnD and Ring). Is it fixed?
    Do hangouts/viber/whatsapp calls still make sounds while in DnD when you have repeat callers on and starred contacts only?
    This is a major bug...
    JaspisB and Loeffelbaer like this.
