235
OxygenOS Open Beta 3 for OnePlus 6
  1. Just4allfun
    Froyo Sep 24, 2018
    Just4allfun , Sep 24, 2018 :
    switched back to stable version...thanks OnePlus for making "OnePlus switch" app so incapable that I have to invest 5 hours in setting up homescreen and login in to each app one by one.
    I will never ever sign up for beta program ever unless a proper backup and restore solution is provided by OnePlus.
  2. Taskman
    Ice Cream Sandwich Sep 24, 2018
    Taskman , Sep 24, 2018 :
    The word BETA is per definition a "test" and you should be ready to reset the phone if needed.
    This goes without saying, or you shouldn't download it in the first place.
    B_Wrath likes this.
  3. Just4allfun
    Froyo Sep 24, 2018
    yes....but try to learn the point which I am trying to make from the post. I am asking OnePlus team to make backup and restore solution less hassle so that more and more people can become beta and make oxygen is even better. If you ever have used or seen apple backup and restore solution u would understand my point.....
    backup up thing in phone then moving to pc then again manually restore to phone. bcz simply the OnePlus switch app do not backup to pc or their is no pc app at all...forget encryption here.
    Meister1977 likes this.
  4. B_Wrath
    Nougat Sep 24, 2018
    B_Wrath , Sep 24, 2018 :
    You have tons of backup apps which do exactly this... Heard of titanium backup??
  5. Just4allfun
    Froyo Sep 24, 2018
    yes....have used it multiple times in different devices....and I am sure you know it require phone to be ROOTED in order to take advantage which will void the warranty.
    please don't suggest to use third-party apps simply because OnePlus don't want to improve native backup and restore solution.
  6. B_Wrath
    Nougat Sep 24, 2018
    Rooting a OP doesn't void their warranty... That's the beauty of OP... And I like the OnePlus switch app.. It really helps me a lot...
    D1531313518896 likes this.
  7. Prateek96@Ind
    Eclair Sep 24, 2018
    Prateek96@Ind , Sep 24, 2018 :
    I faced a problem with my camera app yesterday. It crashes every now and then.. especially when you switch to front cam!
    Didn't know this earlier cos not much of a camera person.
    But the crash happened more than twice! So not by chance.
  8. chazey2
    Jelly Bean Sep 24, 2018
    chazey2 , Sep 24, 2018 :
    You have the wrong zip you need the rollback from beta post.
  9. Shaji06
    Froyo Sep 25, 2018
    Shaji06 , Sep 25, 2018 :
    how to use dark notification symbols??
  10. carva1992
    Eclair Sep 25, 2018
    carva1992 , Sep 25, 2018 :
    Thanks man, I'll try Google Clock
    vriesdejoop likes this.
  11. Mal12345
    Donut Sep 25, 2018
    Mal12345 , Sep 25, 2018 :
    I've been on beta and alpha programs for years with various tech software. I think it is bad that a wipe is required to move to the production version. It should superceed the beta versions and install.
  12. G_Nagaraju_Rangam_ubhD
    Froyo Sep 25, 2018
    G_Nagaraju_Rangam_ubhD , Sep 25, 2018 :
    Battery performance is poor after updating oxygen OS open beta 3 for 1+6. it's draining out as 50% faster then before.
    as per my usage of regular basis after the updated to open beta 3 DRAINS BETTERY FAST. This has to fix.
    As per my observation it's draining 3% in every 1-2min .
    carlosfanini likes this.
  13. vriesdejoop
    Ice Cream Sandwich Sep 25, 2018
    vriesdejoop , Sep 25, 2018 :
    I am more or less expecting that the next update from the production version can be installed over the beta version because then the system update from Android 8 to 9 will not be in the update.
    but of course not sure.
  14. Meister1977
    Gingerbread Sep 25, 2018
    Meister1977 , Sep 25, 2018 :
    Yes, you are right!
    Same issue happens when you move from your old OnePlus to a new OnePlus. This Switch app is joke. The Android buil-in restore did more then this.
    I really want a backup/restore solution. We need to set up 4 2FA application, gmail settings, whatsapp, viber, home screen, all other settings like alarm, ringtone, colors....
  15. dinbandhukumar
    Honeycomb Sep 25, 2018
    dinbandhukumar , Sep 25, 2018 :
    anyone getting this info in playstore tht "Device is Certified"
    I got this one today .. still I'm in open beta 3 ..
  16. badulla.p
    badulla.p , Sep 25, 2018 :
    check it by clearing the cache from recovery mode
  17. ArtuCer
    ArtuCer , Sep 25, 2018 :
    Yes. It's certified from friday. OB3 has the same fingerprint as stable OS9 version.
    dinbandhukumar likes this.
  18. dinbandhukumar
    wow tht nice.,
  19. G_Nagaraju_Rangam_ubhD
    Froyo Sep 25, 2018
  20. badulla.p
    go to recover mode by pressing volume down + power button after shutting down then clear cache. don't wipe data
