235
OxygenOS Open Beta 3 for OnePlus 6
  1. aj2989
    Honeycomb Sep 26, 2018
    aj2989 , Sep 26, 2018 :
    Then I guess the full zip official isnt released yet. When it does it will appear there.
    G_Nader_Kabir_vfEP likes this.
  2. G_Nader_Kabir_vfEP
    Froyo Sep 26, 2018
    G_Nader_Kabir_vfEP , Sep 26, 2018 :
    please help me for download beta 3 for on6?
  3. aj2989
    What do you mean? What version are you running on and what version do you want to upgrade/downgrade to?
  4. Thikalevis
    Gingerbread Sep 26, 2018
    Thikalevis , Sep 26, 2018 :
    if I clever enough than I wouldn't be asking for someone to help me. beta 3 download lastest stable won't let me downgrade that the issue I'm facing.
  5. aj2989
    Thikalevis
    How can I roll back from beta 3 to stable rom? The system said can't upgrade to lower version...​
    Downgrade to oreo (5.1.11), which would require factory reset. Then without restoring your settings just keep doing Ota till Android P stable. Restore settings/apps/data etc after.
    For downgrade to oreo, the link is there at the end of the sticky post in page 1 of this thread (link to OB1 thread).
    Or instead of ota, download this and select local upgrade under system update option (gear icon top right) and select the file you've downloaded. Make sure the file is in your internal storage.
    https://downloads.oneplus.com/oneplus-6/oneplus_6_oxygenos_9.0/
  6. F_Pettinari_Oscar_vnFX
    Eclair Sep 26, 2018
    F_Pettinari_Oscar_vnFX , Sep 26, 2018 :
    Hi guys, as I pass from the beta 3 to the stable? I can 't dowgrade to oreo, the system tells me can't upgrade to lower version...
  7. vriesdejoop
    Ice Cream Sandwich Sep 26, 2018
    vriesdejoop , Sep 26, 2018 :
    oh come on...... READ.....
    it is even explained in the post right above yours for the 254th time....
    zoran81 likes this.
  8. dragonfan
    Froyo Sep 26, 2018
    dragonfan , Sep 26, 2018 :
    hey guys, just upgraded to a OP6 and i can not join the open beta program cause i only find the open beta 2 and its a downgrade compared to the stable OTA. any help where i can find the open beta 3 zip file?
  9. Rakesh_Kumar_T_
    Jelly Bean Sep 26, 2018
    Joffy_Jose likes this.
  10. Rakesh_Kumar_T_
  11. toastytoast1234
    Marshmallow Sep 26, 2018
    toastytoast1234 , Sep 26, 2018 :
    It's an induction test - if you can't find it for yourself, you probably shouldn't be running on Beta.
    B_Wrath, zoran81, Aks41179 and 4 others like this.
  12. Joffy_Jose
    Joffy_Jose , Sep 26, 2018 :
    install the open beta 2 then you will recieve open beta 3 as an ota or use oxygen updater.
  13. dragonfan
    Froyo Sep 26, 2018
    in the official website there is only the stable version and the beta2
  14. Rakesh_Kumar_T_
    Rakesh_Kumar_T_ , Sep 26, 2018 :
    Ok, then Oxygen updater is the way to go
  15. Rakesh_Kumar_T_
    This makes sense[e]1f44d[/e]
  16. F_Pettinari_Oscar_vnFX
    Eclair Sep 26, 2018
  17. H1529937847641
    Cupcake Sep 26, 2018
    H1529937847641 , Sep 26, 2018 :
    After updated now I m facing problem ..after enable automatically call answer ..wherever I m on one call anthore call in waiting automatically answer gone answer mode and on gng call is gone to hold call ..what should I do ?
  18. Funk Wizard
    Lollipop Moderator Sep 26, 2018
    Funk Wizard , Sep 26, 2018 :
    Here are the links to Open Beta 3 with Mirrors:
    Pie Beta 3 Full Zip:
    Official | AFH
    MD5: 7aec26a0b01e555296ce88d7a9c67de3
    Merging this thread to beta 3 thread, please continue discussion there.
    AcmE85 likes this.
  19. F_Anil_Kumar_Savita_cNoA
  20. dhish42
    Froyo Sep 26, 2018
    dhish42 , Sep 26, 2018 :
    disable auto call answer?
