235
OxygenOS Open Beta 3 for OnePlus 6
  1. B_Wrath
    Marshmallow Sep 26, 2018
    B_Wrath , Sep 26, 2018 :
    Beta channel will keep getting updates... It will be ahead of Stable always... Beta 3 is higher version that stable... That's why people couldn't instal directly, because it's a downgrade...
    And the actual beta testers, will never feel that way.. We are here to test and report bugs out of passion.. Not install beta just to get new features and bragging rights..
    lucci_x, aresza20, zoran81 and 2 others like this.
  2. TonioLA
    Ice Cream Sandwich Sep 27, 2018
  3. G_Nagaraju_Rangam_ubhD
    Froyo Sep 27, 2018
    G_Nagaraju_Rangam_ubhD , Sep 27, 2018 :
    Thanks
  4. vriesdejoop
    vriesdejoop , Sep 27, 2018 :
    Totally useless advice, read the sticky post on page one of this threat
  5. G_Nagaraju_Rangam_ubhD
    Froyo Sep 27, 2018
    by the way it's worthy advice.. for me it's working. now battery life is good compare to before.
  6. Shankar Ramanarayanan
    Eclair Sep 27, 2018
    Shankar Ramanarayanan , Sep 27, 2018 :
    You can install the OB2 ROM and immediately you can update to OB3. Worked for me.
  7. dragonfan
    Froyo Sep 27, 2018
    dragonfan , Sep 27, 2018 :
    but i doesn't allow me to do it, cause it says its a downgraded version.
  8. Shankar Ramanarayanan
    Eclair Sep 27, 2018
  9. vriesdejoop
    Then it was the restart that worked for you, not clearing a non existing chache partition!
  10. dragonfan
    Froyo Sep 27, 2018
    my phone information says OS 9.0. odd
  11. G_Nagaraju_Rangam_ubhD
    Froyo Sep 27, 2018
    after updation I restarted my phone twice.
  12. ArtuCer
    Gingerbread Sep 27, 2018
    vriesdejoop likes this.
  13. vriesdejoop
    then try to explain to me how clearing something that does not exist, would have any effect
    if you would like to try it, look at the size of the cache of one of your apps. if you then go in recovery and clear the cache you will see it is immediately at 100% cleared.
    after the restart you will also notice that the time to restart is not longer as usually. In the past this would take at least 1 minute more because of the rebuild of the cache partition.
    the last check would be to look at the size of the cache of the app from the beginning, it is still the same .
    if you then still don't believe me, believe the people of XDA who explained it in a lot of places, just use search.
    This is a very good/clear starting point : https://www.xda-developers.com/how-...ess-updates-affect-custom-development-on-xda/
    AcmE85 likes this.
  14. G_Amit_Tiwari_zcOu
  15. H1536781577934
    Cupcake Sep 27, 2018
    H1536781577934 , Sep 27, 2018 :
    I'm obviously not scrolling through all the responses here, BUT the brightness ISSUE remains a problem to speak about despite the threads about it being closed.
    here starts my personal rant:
    we have paid for a working Brightness sensor, not how "Google has.made it" or how "Google changed it into". it's my absolute right to report what, to me, is an issue/bug, despite it being HOW GOOGLE HAS MADE IT.
    I want my sensor to work, not to "leave it on full brightness" because that's "how Google changed it into".
    fix it in the next update SHOULD really be something to consider.
  16. vriesdejoop
    It's absolute your right to complain, its only hard to fix something that is not broken. Just for a few days adjust the brightness to the setting you like, and the AI system will learn your preference. After adjusting the brightness for a couple of days it will work like a charme and you wont have to touch it again.
    And yes I am sorry for you but thats how google made it. Perhaps you would like to have your Pegeuot car look like a Jaguar, but sorry thats just how they made the Pegeuot. If you don't like it by a Jaguar.
  17. Aks41179
    Jelly Bean Sep 27, 2018
    Aks41179 , Sep 27, 2018 :
    Lol [e]1f602[/e]
  18. A1535867846617
    A1535867846617 , Sep 27, 2018 :
    should I update this version ,I have received it and day ago, will it help me and the device got some new features
    please help me and tell me it's merits and demerits.
  19. H1536781577934
    the "if you don't want a Peugeot buy a jaguar" thing is absolutely nonsense, since that's what the community is here for. report what are the problems found by the community in order to solve them. I don't think we are here to only share other stuff that someone can easily find on XDA. right?
    that said, I reported what for me is a problem. you cannot by a jaguar, use it for some time, then at first time you see a mechanic pulls out your perfect engine and puts a Peugeot inside, telling you "that's how jaguar made it :)". and be quiet about it.
    nice day.
  20. vriesdejoop
    You are right..... Only if its an updated motor you would not complain :D. At least for me I am very happy with the upgraded motor and I don't complain :D:D , ai brightness is working very well for me.
    Then one more thing, if you really think it's a bug or it should change, don't mention it only here, does not help, but use the feedback link. Then it will be noticed by the right people!
