235
OxygenOS Open Beta 3 for OnePlus 6
  1. vriesdejoop
    Ice Cream Sandwich Sep 27, 2018
    vriesdejoop , Sep 27, 2018 :
    You are right..... Only if its an updated motor you would not complain :D. At least for me I am very happy with the upgraded motor and I don't complain :D:D , ai brightness is working very well for me.
    Then one more thing, if you really think it's a bug or it should change, don't mention it only here, does not help, but use the feedback link. Then it will be noticed by the right people!
  2. H1536781577934
    Cupcake Sep 27, 2018
    H1536781577934 , Sep 27, 2018 :
    I will give it some days as you adviced me to, but if it stays this low I'm gonna report it with the feedback thing..
    vriesdejoop likes this.
  3. Mertolias
    Mertolias , Sep 27, 2018 :
    I am on Beta 3. How I can up to stable version without format? Its too important for me.
  4. G_Nader_Kabir_vfEP
    Froyo Sep 27, 2018
  5. vriesdejoop
    you can not, as you could have read before you installed beta.
    but why is it a problem to format, just backup to a PC, and restore after the rollback...
    just ~2 hr connecting the phone to a PC
    Mertolias likes this.
  6. devoncatt
    Gingerbread Sep 27, 2018
    devoncatt , Sep 27, 2018 :
    According to all the posts you have to go back to 8 with a local upgrade and then there will be an OTA upgrade, I am still waiting I did it and still hasn't upgraded. Yes you do get your all data removed when you downgrade you can in theory back up with One Plus switch.
  7. Mertolias
    I back up my datas by Switch. How I can downgrade? And where is my backup? If I downgrade my software is that delete?
  8. Kytharsis
    Marshmallow Sep 27, 2018
    Kytharsis , Sep 27, 2018 :
    Move your backup to a PC or OTG flash drive or else it will be deleted. After doing this, download the rollback zip found on the first page of this thread.
  9. sojilvs
    Cupcake Sep 28, 2018
    sojilvs , Sep 28, 2018 :
    I had updated my OnePlus 6 to beta 3 lately.Now which has some issues like xender connection problem,camera bugs and Google play music is not showing playing music in background from notifications . please fix this one plus
  10. Moin2200
    KitKat Sep 28, 2018
    Moin2200 , Sep 28, 2018 :
    Always clear cache when updating to a new version of android or bugs might occur.
    sojilvs likes this.
  11. sojilvs
    I tried that but not....
  12. youbi
    Portuguese POC Assistant Head Moderator Sep 28, 2018
    youbi , Sep 28, 2018 :
    Threads merged, better discuss this on the official thread about the update.
  13. G_Karothikeyan
    Ice Cream Sandwich Sep 28, 2018
    G_Karothikeyan , Sep 28, 2018 :
    Download and install rollback version rom
  14. zoran81
    Jelly Bean Sep 28, 2018
    zoran81 , Sep 28, 2018 :
    Oh man wait till @vriesdejoop see this advice
  15. H1534068514297
    Eclair Sep 28, 2018
  16. vriesdejoop
    Kytharsis and zoran81 like this.
  17. lxieyang
    Froyo Sep 28, 2018
    lxieyang , Sep 28, 2018 :
    so, Google pay is still not working for open beta while it doesn't seem to be a problem for the stable build?
  18. vriesdejoop
    vriesdejoop , Sep 28, 2018 :
    it is certified now, so it should work. uses the same key as the stable build.
    zoran81 likes this.
  19. zoran81
    It works for me since OP release stabile 9.0
  20. dermot33
    dermot33 , Sep 28, 2018 :
    Yes there are be will beta 4 ready when is
