235
OxygenOS Open Beta 3 for OnePlus 6
  1. jstnbsn
    Eclair Sep 28, 2018
    jstnbsn , Sep 28, 2018 :
    clear data from play services and play store then reboot. then verify in play store settings that the device is certified. should work after that.
  2. Mertolias
    Cupcake Sep 28, 2018
    Mertolias , Sep 28, 2018 :
    Hi, I am on beta. Firstly i will downgrade after i will install Pie stable version. I created backup with Switch but in app information "Without data". Its terrible. Do u have any options?
    Thanks.
  3. FaleshC
    KitKat Sep 29, 2018
    GambitM and LegolasX like this.
  4. NikosTweak
    Cupcake Sep 29, 2018
  5. Funk Wizard
    Lollipop Moderator Sep 29, 2018
  6. k.dhar87
    Donut Sep 29, 2018
    k.dhar87 , Sep 29, 2018 :
    it is in the theme settings under display section of the settings. use either default or colourful option.
  7. Ryanf78
    Gingerbread Sep 29, 2018
    Ryanf78 , Sep 29, 2018 :
    Google pay is working. it works great on OP beta 4. this beta seem really solid. no issues that I can tell.
  8. Mertolias
    Mertolias , Sep 29, 2018 :
    I need help.
  9. Kytharsis
    Marshmallow Sep 30, 2018
  10. Mertolias
    Cupcake Sep 30, 2018
    Mertolias , Sep 30, 2018 :
    Okay. It's impossible :)
    Kytharsis likes this.
  11. Thikalevis
    Gingerbread Oct 2, 2018
    Thikalevis , Oct 2, 2018 :
    I am now running officially one plus 6 successfully thank for the info.
    aj2989 likes this.
  12. aj2989
    Honeycomb Oct 2, 2018
    aj2989 , Oct 2, 2018 :
    You're most welcome.
  13. X1535119214848
    Cupcake Oct 2, 2018
  14. Ryanf78
    Ryanf78 , Oct 2, 2018 :
    what's not giving you good performance. beta 3? try beta 4. it's better.
  15. X1535119214848
    Cupcake Oct 2, 2018
    X1535119214848 , Oct 2, 2018 :
    update is not available
  16. Ryanf78
    are you using oxygen updater from the Play Store? Beta4 is there for download..
  17. Royal yash
    Cupcake Oct 2, 2018
    Royal yash , Oct 2, 2018 :
    but what about camera "please asli fix the problem with camera oneplus 6" the problem is the quality in pictures taken from oneplus 6 mobile is reduced and also the sharpness please oneplus team see to this problem and fix the problem when you leave the stable update
  18. Q1537948917331
    Cupcake Oct 7, 2018
  19. H1528802010363
    Donut Oct 18, 2018
  20. Kafi.bd
    Eclair Nov 15, 2019
    Kafi.bd , via OnePlus 6 , Nov 15, 2019 :
    Hello!
    I am using oneplus 6 right now. I have captured several images with stockcam and gcam. Both the images are not sharp. When i zoom in after taking pictures, the pictures are not sharp.
    Is there any slotuion?
    Currently, i am using OP6_O2_Beta_30
    Regards.
