235
OxygenOS Open Beta 3 for OnePlus 6
  1. Horizon21000
    Honeycomb Sep 16, 2018
    Horizon21000 , Sep 16, 2018 :
    This is normal! They changed the slider so you have more control about the lower brightness levels.
    Adaptive Brightness is now intelligent brightness, so in the beginning you need to adjust the slider very often to give the system information about your preferred brightness in certain condition. Later it will adjust it very accurate to your liking and not only according to environment brightness.
    Its an amazing feature from Android Pie!
    Vladut123 likes this.
  2. F_Shahryar_Shahryari_rQa
    Froyo Sep 16, 2018
  3. wizard19999
    Gingerbread Sep 16, 2018
    wizard19999 , Sep 16, 2018 :
    U have to do the gesture for opening recent apps twice it works for me
  4. p51d007
    KitKat Sep 16, 2018
    p51d007 , Sep 16, 2018 :
    Oppo's OnePlus...releasing beta after beta after beta because they won't spend the time to release good stable software, but, rely on the users to do the testing for them :D
  5. akash2002
  6. ItsSuperEric
    Cupcake Sep 16, 2018
    ItsSuperEric , Sep 16, 2018 :
    Is anyone having any issues installing new apps on the beta from Google Play or is it possibly not related to the beta at all? New apps I'm trying to install stay stuck at 100%, but apps being updated are fine.
  7. tortoise14
    tortoise14 , Sep 16, 2018 :
    No such problem for me
    Vladut123 and ItsSuperEric like this.
  8. Vinay_NS
    Vinay_NS , Sep 16, 2018 :
    And the battery drain problem begins in 3...2...1...[e]1f602[/e] [e]1f602[/e]
    X1528591131881 and Vladut123 like this.
  9. DARA@
    Eclair Sep 16, 2018
    DARA@ , Sep 16, 2018 :
    I using sim smart company in Cambodia VOLTE not working , on stable version also the same
  10. Ariya2018
    Ariya2018 , Sep 16, 2018 :
    Suppose I want to launch the google assistant AND want to retain the feature of restarting /power off the phone . Is that possible without toggling off the new feature for launching the google assistant ? Otherwise it's pretty much useless because primary action of the power button is to power off the phone isn't it ? [e]1f60a[/e]. ( I was hoping the power off menu would come if I press and hold it over .5 secs but ain't working for me )
  11. G_shajahan_km_abcd
    Froyo Sep 16, 2018
  12. Raghav 678
    Eclair Sep 16, 2018
  13. A1535864443819
  14. F_Kaushik_Deshpande_oHvv
    Donut Sep 16, 2018
  15. rtanzeen
  16. Anonymous_1990
  17. Artemus
    Community Hero 2020 Sep 16, 2018
    Artemus , Sep 16, 2018 :
    The instructions are in the OP. Read it.
  18. YellowClaw
    YellowClaw , Sep 16, 2018 :
    seems my hike is unable to receive notifications. I only receive when I open it. Any solutions if possible ?
  19. YellowClaw
    battery life seems excellent on this beta, i got only 3% drop from 100% over night with volte on. Even the device doesn't get much hot.
    Horizon21000 and Vladut123 like this.
  20. badulla.p
    badulla.p , Sep 16, 2018 :
    check whether background data is enabled or not in app info --> data usage
