235
OxygenOS Open Beta 3 for OnePlus 6
  1. @iamsandy
    Gingerbread Sep 15, 2018
    #41
  2. Yashvendra_Singh_Raghav
    Ice Cream Sandwich Sep 15, 2018
    Yashvendra_Singh_Raghav , Sep 15, 2018 :
    keep your naked eye on system updates...m if u r lucky then u will recieve it on very first rollout
    as stable ota's are staged roll out.
    #42
    Vladut123 likes this.
  3. D1517844581455
    Honeycomb Sep 15, 2018
    D1517844581455 , Sep 15, 2018 :
    i guess it should release anything during the next week.
    #43
  4. G_Nikhil_Balasubramanian
    Cupcake Sep 15, 2018
    G_Nikhil_Balasubramanian , Sep 15, 2018 :
    yeah same here, thought it would be resolved it the new update.
    #44
    Vladut123 and @iamsandy like this.
  5. Yashvendra_Singh_Raghav
    oxygen os 5.1.11 was rolled out on 15 aug ... so time has come for oxygen os 5.1.12
    #45
  6. @iamsandy
    @iamsandy , Sep 15, 2018 :
    hope they fix it in the next update
    #46
  7. D1517844581455
    yeah.
    #47
  8. NoInspiration
    #48
  9. F_Elias_Poli_KWOm
    Froyo Sep 15, 2018
    F_Elias_Poli_KWOm , Sep 15, 2018 :
    "Added support to launch google assistant or other third party assistant app by holding power button for 0.5 seconds" very good feature, does it work when display is off?
    #49
    lxieyang and Vladut123 like this.
  10. goku6666
    goku6666 , Sep 15, 2018 :
    New beta is awesome. Thanks for add function apk data backup in oneplus switch. I very need this function when buy new onePlus :D
    So if you can, add function in system android possibility "call recording".
    I know Android 9 erase this from system API, but mayby you can add this?
    #50
    psyop62 and Vladut123 like this.
  11. k.dhar87
    Donut Sep 15, 2018
    #51
  12. Majuran thas
    #52
  13. G_Karothikeyan
    G_Karothikeyan , Sep 15, 2018 :
    Yes, It works......
    #53
    F_Elias_Poli_KWOm and Vladut123 like this.
  14. Himanshu0000608
    #54
    R1536338465931 and Vladut123 like this.
  15. Oldpanda95
    Donut Sep 15, 2018
    Oldpanda95 , Sep 15, 2018 :
    Request to add a feature to the messages app where the OTP can be copied directly from the notification
    #55
  16. Moin2200
    KitKat Sep 15, 2018
    Moin2200 , Sep 15, 2018 :
    Running smoothly so far. Though I find the holding power button for assistant as pretty wierd.
    Couldn't we do a two finger swipe up for assistant?
    #56
  17. Rishik999
    #57
  18. G_Karothikeyan
    #58
  19. guenole_k
    Froyo Sep 15, 2018
    guenole_k , Sep 15, 2018 :
    Finally something to have Google assistant when Navigation gesture is on ! Awesome guys !!!
    #59
  20. utsav17
    utsav17 , Sep 15, 2018 :
    instead of opening assistant with holding power button its much better to use fingerprint sensor long press to launch assistant as it will not put the pressure on power button and cause hardware issues as well as it will prevent the undue long time wait in appearance of reboot bar.
    also after removal of fingerprint drop down notifications in OnePlus 6 its better to put it to some use.
    #60
