235
OxygenOS Open Beta 3 for OnePlus 6
  1. Aks41179
    Jelly Bean Sep 16, 2018
    Aks41179 , Sep 16, 2018 :
    Search for xda open beta 3 oneplus 6
    Vladut123 likes this.
  2. Mikko_P
    Froyo Sep 16, 2018
    Mikko_P , Sep 16, 2018 :
    Aren't we all wait for it ?
  3. E1508089410008
    Cupcake Sep 16, 2018
  4. Rishieric
    Donut Sep 16, 2018
    Rishieric , Sep 16, 2018 :
    Need to work more in battery optimization segment as it is not as good as O2 OS 5.1.11. I know this is a beta version so I don't have any complain regarding this, I know this will improve in future when stable version will be release but as a suggestion it would be better to get in next update.
  5. camohan
    Marshmallow Moderator Sep 16, 2018
    camohan , Sep 16, 2018 :
    Thread merged
  6. suryavmds007
    Donut Sep 16, 2018
  7. TheMysticalShaman
    Honeycomb Sep 16, 2018
    TheMysticalShaman , Sep 16, 2018 :
    With this update. My widgets appeared almost instantly after restart. Before this update. It would take over 20 seconds for the widgets to appear.
  8. jayhawk
    Froyo Sep 16, 2018
    jayhawk , Sep 16, 2018 :
    I just tested a restart. My widgets include Weather Forecast Pro, Nine (for my Outlook calendar), and NY Times. The widgets all loaded 27 seconds after I logged in.
  9. chandra shekar m v
  10. Parthi63
    Donut Sep 16, 2018
    Parthi63 , Sep 16, 2018 :
    today bug's
    I play some video on YouTube when I click landscape mode comes this issue
  11. Samip Kunwar
  12. Horizon21000
    Horizon21000 , Sep 16, 2018 :
    That's why you have this heating issue!
    I don't know why people don't get it. This is a Beta! You need to clear the system if you have a bug. This can be only done by a factory reset!
  13. chazey2
    chazey2 , Sep 16, 2018 :
    If your fastboot boot .IMG then hop over XDA-OnePlus 6 - development -blu spark you need his modded twrp . IMG then you can flash the blu spark installer zip from the same location.
    Aks41179 and Vladut123 like this.
  14. r0y4lc0d3m4n
    Vladut123 and NateDev like this.
  15. NateDev
    Predict23 and Vladut123 like this.
  16. Horizon21000
    When have you done the measurement? The first 2-3 full battery cycles after installing a new update are not valid!
    So far I experienced the battery life improved with the Android Pie Beta (measured in Beta 1 and 2). I was able to receive 10 hours of Screen-On-Time!
    Vladut123 and T1529741874256 like this.
  17. Rishieric
    Donut Sep 16, 2018
    I haven't compared it to beta version, I had totally mentioned ( as compare to O2 OS 5.1.11) yesterday I was on this OS but today I installed O2 OS Open Beta 1 & then updated to Open Beta 3.
  18. MetalSir
    r0y4lc0d3m4n and Vladut123 like this.
  19. rady96
    Donut Sep 16, 2018
    rady96 , Sep 16, 2018 :
    Issues:
    -Snapchat crashes when i am texting and click to send a photo from gallery
    -Youtube zoom now goes beyond the notch. WHY!!
    -Random app crashes
    Suggestions:
    -Youtube zoom not to go past the notch
    -Ability to customise the alert slider abit more. At the moment i cant disable alarms on silent mode
    -more options and customisation to gallery app
    -Add YouTube to parallel (YouTubers rejoice)
    -Google assistant to be triggered by holding finger print reader instead of power button
    NateDev and Vladut123 like this.
  20. abhishekfire
    Eclair Sep 16, 2018
