235
OxygenOS Open Beta 3 for OnePlus 6
  1. Y1537163988654
    Cupcake Sep 17, 2018
    Y1537163988654 , Sep 17, 2018 :
    Add an option where we can change the position of volume bar, to either right side of the screen or the left according to user preference, being right handed having it on the left will be better for not only me but all right handed people.
    Android P brought an option to temporarily go into landscape mode when in an app (like YouTube) but this isn't available when using navigation gestures, having that option when using the same will be great too.
  2. anand.mab
    anand.mab , Sep 17, 2018 :
    just download the beta file and move to the phone's internal storage. go to upgrade and select local upgrade and then select the location of the file where you pasted the beta file.
    Vladut123 and I1534824178011 like this.
  3. Horizon21000
    Honeycomb Sep 17, 2018
    Horizon21000 , Sep 17, 2018 :
    No, it is required for every update!
    Vladut123 likes this.
  4. AliAlfaisal
    Froyo Sep 17, 2018
  5. FaleshC
    KitKat Sep 17, 2018
    FaleshC , Sep 17, 2018 :
    it doesn't work like that.
    Google designed in a way that whichever side volume buttons are the bar appears on same side.
    cy8berdriver, GambitM and Vladut123 like this.
  6. JAGADISH BHATTA
    Jelly Bean Sep 17, 2018
    JAGADISH BHATTA , Sep 17, 2018 :
    Wait for stable Android P
  7. G_Karothikeyan
    Ice Cream Sandwich Sep 17, 2018
  8. vriesdejoop
    vriesdejoop , Sep 17, 2018 :
    I don’t know on what version you are, ques its DP3. But definitely not on beta 3, security June??? should be September.
    So start by installing beta 3, all your problems will be gone!
  9. J1535518237687
    Froyo Sep 17, 2018
    J1535518237687 , Sep 17, 2018 :
    ok then...happy resetting every 10 days..enjoy
  10. Horizon21000
    I talked about waiting 2-3 battery cycles before measuring the battery life.
  11. J1535518237687
    Froyo Sep 17, 2018
    what...thread is not about battery...only about reset
  12. aj2989
    Stickied Post
    aj2989 , Sep 17, 2018 :
    ~~~~~~ Known Issues - Beta 3 ~~~~~
    September 18
    When viewing downloaded videos from download folder, the brightness automatically reduces drastically within a few seconds of viewing. Disabling adaptive brightness or manually increasing the brightness bar to even 100% does not fix it(still becomes very dim).
    Some Apps (Including Youtube ) are missing in App display in fullscreen list.
    "Recent Apps on Shelf goes back to original size after resizing it.
    Proper naming on the app cards. Example, Google Assistant will have it's own card yet it's only listed as Google beside the three dots. This also applies to Data Usage, Storage and Battery when opening them from the Dashboard.
    Issues encountered on the recents menu as well as the Google NavBar such as:
    • When using the Google NavBar really quickly to go to the recents menu, it shows a smaller "x" than normal.
    • Referring from above, it will also display a blacked out card hovering over other cards sometimes.
    • Can't open recents menu while on Shelf and App Drawer.
    • Tapping the home button while on Google Assistant needs to be fixed."
    Thanks to @Jack_Sparrow_ for pointing out some of the issues.
    Bluetooth Issues with phone calls (Car stereo system & some headphones) - the option doesn't stay selected after disabling/enabling bluetooth.
    When using "pill" navigation gestures... the swipe home (pill) to right in landscape doesn't switch to last used app, which works in portrait mode though.
    September 19th
    Lock screen wallpaper not appearing darker if both home and lockscreen - same wallpaper, are applied at the same time. Applying seperately for home and lock seem to fix the issue - You guys can let me know if I'm wrong though.
    Fingerprint sensor sometimes becomes unresponsive at random - don't know what triggers this. If someone finds out do let me know.
    Do let me know on what issues you face on beta 3 (I'm not including the fixed ones from beta 2) by tagging me @aj2989 or replying to this.
    Will edit this as we discover more bugs or if I have missed out on any existing ones.
    NOTE:
    Some Features of Android P are mistaken as issues or bugs (Example : Screen Brightness Slider threshold and Volume Rocker adjusting Media over Ring/notification).
    Please post your bug reports here to get it fixed officially.
    Clearing Cache via Recovery(apparently does nothing) So read up on this quote from XDA
    "In addition to the other changes, the cache partition has been removed. It now resides in the data partition and is no longer used for anything related to updates. One result is that wiping cache in TWRP no longer does anything.If you want to clear cached data go into Settings>Storage & memory, then tap Cached data at the bottom and then tap OK. (This option is missing - Not sure if that's a P feature - Someone who knows about this do let me know)
    Try at your own risk.
    Uninstalling and re-installing apps causing issues seems to fix the issues for some.
    Clearing Cache of the apps causing issues seem to fix issues for some.
    Factory Reset seems to fix some of the issues - try at your own risk after taking a backup.
    For Downgrading to Official and receiving official updates - Instruction in page 1
    https://forums.oneplus.com/threads/oxygen-os-open-beta-1-for-the-oneplus-6.898938/
    PS: I am not part of the staff, just taking note of common issues and putting it on a single post for everyones benefit. Please do not DM me to fix the issues.
    Thanks for understanding.
    @Funk Wizard here you go again.
  13. Horizon21000
    No, it was about battery drain!
    I suggested to do a factory reset, restrict background services and wait 2-3 battery cycles.
  14. G_Amit_Tiwari_zcOu
    Gingerbread Sep 17, 2018
  15. ganeshm1248
    ganeshm1248 , Sep 17, 2018 :
    oftentimes I deal with network and signal promble..I need to off and on mobile date..and something showing as app not responding..how to fix it
  16. itsMK.
    Froyo Sep 17, 2018
    itsMK. , Sep 17, 2018 :
    Now the volume is working on lock screen as well, that's the best thing about OnePlus keep on refining keep on fixing, well done [e]1f44d[/e]
    7290 and Vladut123 like this.
  17. AkshayDeore
    Donut Sep 17, 2018
    AkshayDeore , Sep 17, 2018 :
    I am using open beta 3 from 2 days, OnePlus should solve following issues in next update
    1.Slow Battery Charging
    2.Camera Performance
  18. ganeshm1248
    how to update beta 3
  19. veasnakit
  20. snuckem
