235
OxygenOS Open Beta 3 for OnePlus 6
  1. Rockstar_Spider
    Froyo Sep 17, 2018
    Rockstar_Spider , Sep 17, 2018 :
    First question, is your computer connected to internet through cable or wifi? Cause there's a lot of difference of speed when you connect the device through lan cable.
    I have a laptop in which I've tested the wifi speed and both had the same results. Turn off your wifi device and turn it back on after 15 seconds and connect both mobile and pc to wifi and check the speed?
    Vladut123 likes this.
  2. HN_Naveenkumar_Style
    Eclair Sep 17, 2018
  3. Rockstar_Spider
    Froyo Sep 17, 2018
    Airtel Volte was unavailable due to some technical glitch in airtel . Its being rolled out to users slowly. Kindly check on the airtel website. Even i didn't have Volte for a few days when I contacted them, they told me that its due to some glitch. They'll notify when its available. And yes now i have Airtel Volte Enabled.
  4. Riztnack
    Eclair Sep 17, 2018
    Riztnack , Sep 17, 2018 :
    Enable the feature...
  5. SoniaB
    Nougat Head Moderator Sep 17, 2018
    SoniaB , Sep 17, 2018 :
    Hey @AmbroiseD I am merging your thread with the beta release thread
    Any issues, please post in this same thread for assistance.
    Its true that from stable to beta you can just do a dirty flash without a full data wipe. Only if you revert back to stable from Beta will a full wipe be recommended.
    After you download the beta zip file, you must move it to root storage. Then update via system update-> local upgrade. Your device will update and then prompt you for a reboot.
    Also, for us to know what build you are on, you need to go to "about phone" in your device settings.
    Vladut123 and AmbroiseD like this.
  6. Deactivated User
    Sep 17, 2018
  7. HN_Naveenkumar_Style
    Eclair Sep 17, 2018
  8. FaleshC
    KitKat Sep 17, 2018
    FaleshC , Sep 17, 2018 :
    update the Oneplus launcher to 3.0 from apkmiror
    or
    Factory Reset.
    cy8berdriver, Vladut123 and AmbroiseD like this.
  9. Riztnack
    Eclair Sep 17, 2018
    search the settings with "power button", I will come up
  10. Riztnack
    Eclair Sep 17, 2018
  11. HN_Naveenkumar_Style
    Eclair Sep 17, 2018
    Vladut123 and Riztnack like this.
  12. VforVanchi
    Froyo Sep 17, 2018
    VforVanchi , Sep 17, 2018 :
    How is the battery guys? I remember someone sharing the screenshot for open beta 2 which showed a crazy 10 hours screen on time... Not sure if it was a fake though!
  13. AmbroiseD
    Cupcake Sep 17, 2018
    AmbroiseD , Sep 17, 2018 :
    Thanks a lot... it worked
    Huge thanks !!
  14. FaleshC
    KitKat Sep 17, 2018
    No problem!!;)
  15. Artemus.
    Nougat Sep 17, 2018
    Artemus. , Sep 17, 2018 :
    Use the beta thread, please.
    Vladut123 and Aks41179 like this.
  16. SoniaB
    Thread merged
  17. AmbroiseD
    Thank you very much !
    Vladut123 and SoniaB like this.
  18. rohinsingh26
    Eclair Sep 17, 2018
    rohinsingh26 , Sep 17, 2018 :
    In landscape orientation I am not able to switch to the last app with the pill gesture(swipe pill to the right). Kindly look into it.
  19. aoprea1975
    Froyo Sep 17, 2018
    aoprea1975 , Sep 17, 2018 :
    who is developer so stupid to open google assistant with power button press 0.5 sec ??? ...
    has tested this before launch ???
    what if i press 0.6 or more secconds ? shut down over ga ....
    why not use fingerprint scanner long press ???
  20. Riztnack
    Eclair Sep 17, 2018
    Really..to say a dev is stupid? What have you developed for the oneplus 6 beta?
