235
OxygenOS Open Beta 3 for OnePlus 6
  1. JuanseAlvarezTorres
    Donut Sep 17, 2018
    JuanseAlvarezTorres , Sep 17, 2018 :
    sure the instructions are on the support page of OnePlus
    Vladut123 and ShyamDeCruze like this.
  2. ShyamDeCruze
    Donut Sep 17, 2018
    Vladut123 likes this.
  3. ArtuCer
    Gingerbread Sep 17, 2018
  4. Afssbill
    Cupcake Sep 17, 2018
    Afssbill , Sep 17, 2018 :
    Only one issue so far with Beta 3. In the phone app, the loudspeaker icon does not highlight when putting calls on loudspeaker.
    The other thing I just noticed is toying here - there is no suit capitalisation when starting new sentences and it does that in text messages too - g-board keyboard.
    Otherwise so far so good
  5. Kerngehirn3
    Honeycomb Sep 17, 2018
    Kerngehirn3 , Sep 17, 2018 :
    Is it possible to quick switch between apps by double tapping the recents button? Like it used to be on oreo?
  6. zoran81
    Jelly Bean Sep 17, 2018
    zoran81 , Sep 17, 2018 :
    There is a bug in OP2 and 3.
    When using Runtastic or Waze (apps that uses GPS) and lock the screen, apps crushes. Extremely annoying when using Runtastic.
    I reported this already but I wonder does anyone else experience this?!
  7. vjayy7684
    Eclair Sep 17, 2018
    vjayy7684 , Sep 17, 2018 :
    please go to settings then utilities and you can find the settings related to app lock .
  8. crmodi86
    Donut Sep 17, 2018
    crmodi86 , Sep 17, 2018 :
    W1529048692570
    does anybody facing issue with ambient display​
    same issue in ambient display.... suddenly changing ....
  9. vjayy7684
    Eclair Sep 17, 2018
    yes I am facing some issues with ambient display as I need to adjust brightness many times but I think our usage patterns are been saved soon and we do not need to adjust it later on
  10. Shankar Ramanarayanan
    Eclair Sep 17, 2018
    Shankar Ramanarayanan , Sep 17, 2018 :
    Thank you buddy. Appreciate it.
    Vladut123 and vjayy7684 like this.
  11. YellowClaw
  12. U1528949738327
    Eclair Sep 17, 2018
  13. chazey2
  14. davidvese
    davidvese , Sep 17, 2018 :
    i cant disable fullscreen mode when i watching youtube
    i try to find that option in Settings>Display>App display in fullscreen but i cant find youtube there
    can someone help me?
  15. x01
    Donut Sep 17, 2018
    x01 , Sep 17, 2018 :
    Just install beta one, and you will recive beta 3
  16. arnav_89
    Froyo Sep 17, 2018
    arnav_89 , Sep 17, 2018 :
    Are you using the new pill navigation? If so, you can swipe right on the pill to switch.
  17. Q1535779076097
  18. Kerngehirn3
    Nope. I hate the new recents and the pill navigation and the gestures. I just want to use the good old navigation bar and switch quickly with the recents button. For example when I'm in the car using maps and get a phone call. The phone switches to the caller app and for whatever reason no picture in picture appears. Either way, when I get a call I want to quickly switch back to maps. I don't want to move some pill to just get one app to far and have to go back. Just inconvenient.
  19. arnav_89
    Froyo Sep 17, 2018
    Power + volume down. If you turn on the gesture then you can swipe down with 3 fingers.
  20. Sudhanshu Joshi SDD
    Sudhanshu Joshi SDD , Sep 17, 2018 :
    its by default..just play video and do pinch zoom..video will cover full screen..just try it
