235
OxygenOS Open Beta 3 for OnePlus 6
  1. Sudhanshu Joshi SDD
    Honeycomb Sep 18, 2018
    Sudhanshu Joshi SDD , Sep 18, 2018 :
    this is becaus of adaptive battery option you have enabled.
    Vladut123 likes this.
  2. YellowClaw
    YellowClaw , Sep 18, 2018 :
    it is disabled
  3. Sudhanshu Joshi SDD
    yes i know..thats why i am saying it is poor for me thn beta 2, its been only 2-3 week..my activities are nearly same..i am not doing anything new
  4. Sudhanshu Joshi SDD
  5. YellowClaw
    hike too ?
  6. YellowClaw
    maybe i will try downloading the whole zip file and clean flash it
  7. FaleshC
    KitKat Sep 18, 2018
    FaleshC , Sep 18, 2018 :
    Yeah v3.0 is only for 9.0 as of now.
    For Oreo v2.5.1.xx
    cy8berdriver, Vladut123 and iamtrunal like this.
  8. rjforbarcelona
    Cupcake Sep 18, 2018
  9. notcyf
    notcyf , Sep 18, 2018 :
    Anyone know if in OB3 the touch latency is fixed? It was horrible in OB1 & 2 and I switched back to stable(in which it's also not that good but a lot better).
    alami.shayan and Vladut123 like this.
  10. YellowClaw
    for some reason i dirty flashed the rom and everything works fine with both apps.
  11. Rajput_Sahab
    Froyo Sep 18, 2018
  12. vriesdejoop
    Ice Cream Sandwich Sep 18, 2018
    vriesdejoop , Sep 18, 2018 :
    No, you did not do a clean flash!
  13. nandhan.nandhan
    Froyo Sep 18, 2018
  14. vjayy7684
    Eclair Sep 18, 2018
    vjayy7684 , Sep 18, 2018 :
    nandhan.nandhan
    HOW TO WIPE CACHE data IN RECOVER MODE?​
    first power of your phone then press volume down button and power button at once as you phone reboot it will reboot in recovery mode select language then select wipedata and cache then select delete cache and reboot your phone it's simple but I request you to read all instructions carefully before selecting any function thankyou
  15. nandhan.nandhan
    Froyo Sep 18, 2018
    nandhan.nandhan , Sep 18, 2018 :
    i am tried , but not working.
  16. R1534850131552
  17. R1534850131552
  18. JAGADISH BHATTA
    Jelly Bean Sep 18, 2018
    JAGADISH BHATTA , Sep 18, 2018 :
    Then you should have opted for iphone
  19. vriesdejoop
    Please, wipe data in recovery is useless anyway. On our OP6 there is no cache partition anymore, so wiping something that is not there is useless. Please read about AB partitioning and the effects on op6 for example on XDA and stop giving an advice that does not do anything anymore.....
    Only way to wipe cache is in settings...apps... and only one app at the time or start using a app like SD maid.
  20. R1534850131552
