235
OxygenOS Open Beta 3 for OnePlus 6
  1. chazey2
    Jelly Bean Sep 18, 2018
    chazey2 , Sep 18, 2018 :
    Use the blu spark TWRP .img search XDA for blu spark modified TWRP, from memory it's twrp 9.85v2
    Vladut123 likes this.
  2. amogh.rane
    Donut Sep 18, 2018
    amogh.rane , Sep 18, 2018 :
    I flash the modified .IMG and then I flash the zip as well. Then I reboot to recovery and then flash Magisk. But when I reboot system, I get crashdump
  3. gubro
    KitKat Sep 18, 2018
    gubro , Sep 18, 2018 :
    Kindly stop shouting.
    Also, kindly ask you to understand, that this is a customer forum.
    Kindly read the first post and kindly try to understand the bug reporting procedure.
    Also kindly Google this issue, there will be plenty of information available, kindly read it.
    Vladut123 and Aks41179 like this.
  4. Sarfarazahmed9
    Cupcake Sep 18, 2018
    Sarfarazahmed9 , Sep 18, 2018 :
    Since update to OS openbeta 3, I have noticed under storage in system app it shows 8.7 gb used... Is it normal? And if have to get more free space what to do... Please help.
  5. chazey2
    Fastboot the TWRP.img then from TWRP flash the installer zip. Reboot to TWRP
    Wipe everything except internal/usb from advance unless you have USB OTG flash the Rom .zip re-flash the TWRP installer .zip Reboot to system do initial setup then reboot to TWRP flash Magisk 17.1 reboot
  6. A1536843583599
  7. SadButTrue
    Ice Cream Sandwich Sep 18, 2018
    SadButTrue , Sep 18, 2018 :
    OMG yet another guy who isn't even able to take a look at google to get a little bit more info before he is posting crap...
    maybe you should inform yourself BEFORE posting!
    i give you a little hint machinelearning/KI adaptive brightness...
    i can't take this kind of postings any more - cupcakes without knowledge but testing betas... OMG...
  8. amogh.rane
    Donut Sep 18, 2018
    Can I flash xXx, Or does it contribute to the crashdump?
  9. Senogle02
    Senogle02 , Sep 18, 2018 :
    Downloaded Open Beta 1 and currently on Open Beta 3 via OTA updates. Is it true that I'll have to wipe my phone completely to update to the Andoid Pie stable build when it's released? is there a work-around for this? Thanks for the help! Loving Android Pie on my OP6!
  10. OnePlus_8t
    OnePlus_8t , Sep 18, 2018 :
    sometimes , minimum cpu frequency is 1056 instead of 576 , when restart device it go back to 576 for a while and then again 1056
    and , device freezes for seconds , status bar disappears
  11. Magnetic Nerd
    Magnetic Nerd , Sep 18, 2018 :
    for everyone posting battery issues with builds I just need to point out something.
    battery drain is normal, you'd think people on here expect the battery not to drain but it all depends on what you're actually doing in your phone. you're not going to use you're phone the exact same every day. your signal is not going to be the same every day and this depending on what you're doing will show different battery levels.
    for example today I got 6h SoT before I turned on battery saver and I'll see how much more that nets me.
    tomorrow? hell I could get less or more. there's so many variables and rouge apps that can cause battery drain (hello Facebook app)
    I know 90% of this forum won't listen/read but honestly before you start wasting development time by posting useless things such as "my battery drain fast' etc actually take time and see what's causing it first. get proper evidence if it's actually draining fast, check for wakelocks, check your apps actually put in some work so that we as a community can help OnePlus and not hold them back investigating what could be nothing.
    this is probably the biggest post ive done on here but i feel that the OP bug hunters and software team need all the help they can get from here.
    and finally if you're 99.9% sure there is a battery drain in the software get a bug report and send it to OnePlus!! just saying "battery drain" and following it up with nothing is going to help nothing.
    /rant?
    Vladut123, robmoh, B_Wrath and 2 others like this.
  12. s1lence
    s1lence , Sep 18, 2018 :
    I don't get any notifications from Snapchat after updated to beta 3. I have notification on in settings, every batterysaver function turned off and have checked internal settings for Snapchat itself. Also tried re-installed it. Any suggestions?
    Edit: All other apps SEEMS to be ok.
  13. F_Elias_Poli_KWOm
    Froyo Sep 18, 2018
  14. Senogle02
    Nope. Thats a new "feature" in Pie. Supposed to take up less of your task bar space.
    Vladut123 and F_Elias_Poli_KWOm like this.
  15. Horizon21000
    Honeycomb Sep 18, 2018
    Horizon21000 , Sep 18, 2018 :
    Yes, thats normal! You had around this size already before (maybe you didn't notice it).
    The OnePlus 6 have two System Partitions, so basically you have installed two Android version at same time. Thats how the seamless updates working.
    Haven't you wondered why the phone doesn't need to reboot to recovery install there the update and boot back?
    Now the install process happens when you still use your phone and you just need to reboot so the phone boots the other partition where the new update was installed.
    So you will always loose around 4-5GB just for this function. This was one of the reasons why I choosed the 128GB version!
  16. kiss.tibor741
  17. ade0410
    ade0410 , Sep 18, 2018 :
    well thank you for sharing such insightful and useful information. failed how?
  18. V1534979208787
  19. kiss.tibor741
    Cupcake Sep 19, 2018
    kiss.tibor741 , Sep 19, 2018 :
    sorry, I just wanted to let you know that the new update is much faster than the previous one.
  20. Tonhocruz
    Froyo Sep 19, 2018
    Tonhocruz , Sep 19, 2018 :
    I'm considerating never going back to official ota path, this beta is just awesome
    (but If i wanted to go back to the official path, how can i do it?)
