235
OxygenOS Open Beta 3 for OnePlus 6
  1. aj2989
    Honeycomb Sep 19, 2018
    aj2989 , Sep 19, 2018 :
    The clear cache option (system wide) used to be present in oreo under storage and memory, but it's not available in P. Also, clearing cache from recovery does absolutely nothing due to A/B partition, hence clearing individual app cache or performing a full wipe are the only working options.
    Vladut123 likes this.
  2. iam_GAS
    Froyo Sep 19, 2018
    iam_GAS , Sep 19, 2018 :
    I am experiencing problem with sound. Sound in some apps come through earpiece instead of speakers. Ex.- PUBG, Chrome
  3. aj2989
    Things to try in the meantime:
    Clear Nova Launcher cache.
    Reinstall Nova Launcher.
    Try in Oneplus Launcher.
    Use a different wallpaper for lock screen.
    Disable Pin password and try with pattern for both Nova and oneplus launchers.
    Get back to me if/when you've tried these out.
    Vladut123 and Croc97 like this.
  4. saahill
    Gingerbread Sep 19, 2018
    saahill , Sep 19, 2018 :
    I guess I can't perform a full wipe. I'll just clear the individual app cache!
    Thanks for for the help. I mean consolidating the bugs.
    Appreciate it man! :)
    Vladut123 and aj2989 like this.
  5. aj2989
    Your welcome :) it's actually a funny story - I requested someone to do this on beta 2 thread and Funk wizard (moderator) replied that if I did the work, he would sticky my post. So here we are [e]1f601[/e]
    Vladut123 and saahill like this.
  6. saahill
    LOL!
    It sure is!
    Appreciate it man!
  7. darryl.antonio
    Eclair Sep 19, 2018
    darryl.antonio , Sep 19, 2018 :
    Is it true that if I am in beta version and in case the final or stable version of P is available via OTA, I need to rollback on the stable version to get the released stable or final version of P? That means, I have to downgrade to the latest build version which also means everything on my phone will be wiped out? Thanks in advance!
  8. nitin13727
    Froyo Sep 19, 2018
    nitin13727 , Sep 19, 2018 :
    Brother this is not the forum to cry like a kid. Grow up. Betas are rolling out for us to test and report bugs so that impatient chaps like you may get a stable pie update sooner.
    You want pie then install the beta and help the engineers with bug reports and logs instead of whining or just wait.
    Pie is not the end of life nor it will change yours for something meaningful. Let people do their job.
  9. vyshnavpisharady
    Eclair Sep 19, 2018
    vyshnavpisharady , Sep 19, 2018 :
    hm ok
  10. nitin13727
    Froyo Sep 19, 2018
    I guess we would install the stable P full zip through local upgrade over the OB and make a factory reset in recovery before booting.
    I personally would give it a go without wiping.
  11. Lijo Johnson
    Cupcake Sep 19, 2018
  12. Lijo Johnson
  13. darryl.antonio
    Eclair Sep 19, 2018
    nitin13727
    I personally would give it a go without wiping.​
    I see, basically the option to get the stable version once released is to manually download the zip file because we won't get it via OTA. Am I understanding it right? Thanks for the info by the way! [e]1f601[/e]
    Oh you mentioned that along the process "factory reset in recovery mode" is part of it? Is it a must? To setup again my stuff like apps, settings, etc.?
  14. Y1534679539049
    Y1534679539049 , Sep 19, 2018 :
    mobile gets freezed at home screen. have to manually restart the phone. it's just been a month I have purchased the phone
  15. JAGADISH BHATTA
    Jelly Bean Sep 19, 2018
    JAGADISH BHATTA , Sep 19, 2018 :
    Read first page of this thread this is not a bug but google has done it
  16. JAGADISH BHATTA
    This should work like this if you don't want notch interfering your youtube then don't use pinch in to zoom
  17. F1533051500940
    Donut Sep 19, 2018
  18. Drsj
  19. JAGADISH BHATTA
    You do realize no one from one plus is monitoring this thread please post your finding on support> Bug Reports
  20. YellowClaw
