235
OxygenOS Open Beta 3 for OnePlus 6
  1. JAGADISH BHATTA
    Jelly Bean Sep 19, 2018
    JAGADISH BHATTA , Sep 19, 2018 :
    Report in on support>bug reports
    Vladut123 likes this.
  2. Drsj
    Gingerbread Sep 19, 2018
    Drsj , Sep 19, 2018 :
    can you post screen shots when possible, already getting 7hrs plus SOT , NOT ON BETA
  3. JAGADISH BHATTA
    You will be always getting beta updates unless you flash stable and upgrade to official P
  4. G_lokesh_s_gGjG
    Cupcake Sep 19, 2018
    G_lokesh_s_gGjG , Sep 19, 2018 :
    I haven't updated to any of the beta's,but now I'm thinking to update to beta, so should I go Directly to beta 3 r beta 1
  5. YellowClaw
    Honeycomb Sep 19, 2018
    YellowClaw , Sep 19, 2018 :
    i can provide the screenshots when the day i am unable to play pubg. Maybe 1-2 days when m back at work.
    Vladut123 and Drsj like this.
  6. ruffinsky
    Froyo Sep 19, 2018
    ruffinsky , Sep 19, 2018 :
    7hrs SOT on WiFi, how mnay hours since unplugged, good cell connection? A screenshot would be very helpful. Thanks
  7. Jai Godara 7269
    Froyo Sep 19, 2018
    Jai Godara 7269 , Sep 19, 2018 :
    thanks bro for the information
  8. vardaanchawla
    vardaanchawla , Sep 19, 2018 :
    Amazing work by the OP team!
    I've never experienced such a stable beta version of any OS.
    would absolutely love it if you guys can give a double press power for camera, and swipe down on fingerprint sensor for Notification shade.
    both would make daily usage a lot more convenient!
    Also, just dragging an app from the recents for split view would be great!
    And if there are any reasons for not giving these features, please explain, for our information :)
    keep up the great work!
    regards!
    Vladut123, aresza20 and Drsj like this.
  9. tortoise14
    tortoise14 , Sep 19, 2018 :
    Ad guard is working fine in my case.
  10. KetanRaut
    Froyo Sep 19, 2018
  11. nitin13727
    Froyo Sep 19, 2018
    nitin13727 , Sep 19, 2018 :
    factory reset in recovery is recommended when switching from beta to stable. Alternatively you can start without wiping and if u face any issues u will have to wipe anyways.
  12. G_Yogendra_Deshmukh_geYA
  13. KetanRaut
    Froyo Sep 19, 2018
  14. M1511585815274
  15. magnettron
  16. LippyA
    Eclair Sep 19, 2018
  17. Kakashi84
    Kakashi84 , Sep 19, 2018 :
    hi, I have a problem with gpay .
    it's a bug of beta that says that have a root that I haven't.
  18. P1523468751791
    P1523468751791 , Sep 19, 2018 :
    Bonjour,
    Je n'arrive pas à mettre à jour mon appareil vers cette version, une fois le pack téléchargé je ne peux pas démarrer le processus d'installation, quelqu'un pourrait-il m'aider ?
  19. stoske
    Donut Sep 19, 2018
    stoske , Sep 19, 2018 :
    For me the only issue that I have is battery drain. With open beta 2 I had amazing battery life, now I cannot make half day.
    My usage is the same as well the apps that I am using.
  20. NAITIKD
