235
OxygenOS Open Beta 3 for OnePlus 6
  1. arnav_89
    Froyo Sep 20, 2018
    arnav_89 , Sep 20, 2018 :
    I have encountered a bug with battery usage stats. If I go to usage totals it shows me all the apps but when I click on one of the apps and go back it only shows the top 4. This also happens if I stay on the stats for some time (around 10 sec). Has any one faced this? If others have faced this then I will report it as a bug.
  2. Marek_Orovnicky
    Honeycomb Sep 20, 2018
  3. Muhammad_Kashif_bahl
    Gingerbread Sep 20, 2018
    Muhammad_Kashif_bahl , Sep 20, 2018 :
    dear please add native call recording feature.
    Hi dear oneplus team.
    I have bought new oneplus 6 and found a discrepancy in it and i would like to draw your attention to this defficiency of call recording feature in dailer manu, because today in every smart phone or leading smart phone have this feature.
    i am from pakistan and want to use this feature, because it is necessary for my job.
    Please add this feature in oneplus 6 via update.
    i am attaching here a screenshot for reference.
    i am waiting for your kind response.
    Regards.
    Muhammad Kashif
  4. Muhammad_Kashif_bahl
    Regards.
    Muhammad Kashif
  5. B_Wrath
    Marshmallow Sep 20, 2018
    B_Wrath , Sep 20, 2018 :
    Don't give it your phone number on the forum!!! Its not secure... Delete it immediately!!
    Also, call recording is available only if it is allowed by law in your country....
  6. Darshan_247
    Froyo Sep 20, 2018
    S1536022592186 likes this.
  7. S1536022592186
    Eclair Sep 20, 2018
    Darshan_247 likes this.
  8. Darshan_247
    Froyo Sep 20, 2018
    Darshan_247 , Sep 20, 2018 :
    S1536022592186
    I think there's a battery drainage issue. I think it lasted longer in beta 2.​
    i dont know about beta 2 coz i directly installed beta3, but audio output is very low
  9. aj2989
    aj2989 , Sep 20, 2018 :
    Yes it's behaving the same for me as well, but I don't know if it's a P feature.
  10. arnav_89
    Froyo Sep 20, 2018
    I will send a feedback on this. Let's see what the devs say about it.
    aj2989 likes this.
  11. aj2989
    Keep me posted and I will add it to known issues if it checks out.
  12. arnav_89
    Froyo Sep 20, 2018
    Will do
    aj2989 likes this.
  13. B_Wrath
    It is an issue .. Even i have it... A clean install too doesn't seem to help.. You can add it to the sticky...
  14. zoran81
    Jelly Bean Sep 20, 2018
    zoran81 , Sep 20, 2018 :
    Oh, man..giving phone number is not so clever
  15. aj2989
    Yes but it could be some P feature showing us the most battery consuming apps or something. Let me do some research too.
  16. E1536926587914
    Cupcake Sep 20, 2018
  17. Sudhanshu Joshi SDD
    Sudhanshu Joshi SDD , Sep 20, 2018 :
    16 min on screen and 20 % drop.. worst battery backup..
    i think they intentionally not giving stable version since 6t launching next month and it is coming with pie
  18. Horizon21000
    Horizon21000 , Sep 20, 2018 :
    But the OnePlus 6 is definitely not a Mid-range Phone!
    The weakest point of the phone is the camera but never, never, never the performance!
    It outperforms easily every other Android Phone out there (even with Snapdragon 845). To complain about scrolling performance is ridiculously!
    If you have issues here, it is either your OnePlus 6 om special and you should do a factory reset or OxygenOS itself.
    In this case flash a custom rom!
  19. Akashganga99
    Akashganga99 , Sep 20, 2018 :
    when I downgrade from Android pie 9.0 to Android Oreo 8.1, there was a error (showing in picture).
    aftethat I wipe data & cache and again enable oem unlock & downgrade DP Rom to MP Rom but same error show again..
    help me guys
  20. Horizon21000
    Give it some time. Make some full battery cycles until you judge.
