82
OxygenOS Open Beta 3 for the OnePlus 6 and OnePlus 6T
  1. shimanshu4590
    Froyo Dec 18, 2019
    shimanshu4590 , Dec 18, 2019 :
    It's a bug. It comes with this update. Notch hide thing worked very in previous update.
  2. Farhanmohmmd
    Cupcake Dec 18, 2019
    Kerngehirn3 and Caoimhín like this.
  3. Caomhin
    OnePlus 9 Series Expert Community Expert Dec 18, 2019
    Caomhin , via OnePlus 6T Mirror Black , Dec 18, 2019 :
    My SOT runs at about 10% of Battery per hour, see post further up the thread, My phone has always ran like this, so for 100% of Battery I am getting approx 10 hours SOT with no gaming.
    The amount of apps you have had no bearing on a factory reset suggestion. You would factory reset to correct issues within the Android OS, whether you have 1 App or a thousand.
    And you have many more than 1 app, every device comes with Hundreds of Apps installed, including system only Apps.
    Check Battery stats to see which are using the most percentage of battery.
  4. Kerngehirn3
    Honeycomb Dec 18, 2019
    Kerngehirn3 , via OnePlus 6 , Dec 18, 2019 :
    It's not unusable,
    You can unhide the notch.
    Furthermore, less useless screen, more battery. ;)
  5. efks
    Ice Cream Sandwich Dec 18, 2019
    efks , Dec 18, 2019 :
    i did factory reset after upgrade
  6. FiloSvR
    Donut Dec 18, 2019
    FiloSvR , Dec 18, 2019 :
    Because I work with my phone and I don't have time to factory reset again. Oneplus backup suite is not great.
  7. Caomhin
    efks
    i did factory reset after upgrade​
    And how do the app battery stats work out, have you checked to see which apps are using most battery, try force stopping any offending apps.
    Also try Battery Optimization in settings battery, and restrict any apps you don't require to run in the background causing issues. Don't restrict system apps.
  8. Caomhin
    That's up to you, but if you have tried every other option and suggestion it may be the only recourse open to you. Again entirely your choice.
  9. efks
    Screenshot_20191218-130621.jpg Screenshot_20191218-130604.jpg Screenshot_20191218-130621.jpg Screenshot_20191218-130553.jpg
  10. Caomhin
  11. bojantomic
    bojantomic , via OnePlus 6T , Dec 18, 2019 :
    It's not a bug. That's how it works. Just look at the Pixel 3's implementation. That's why this feature is useless. You loose more screen than with the notch.
  12. bojantomic
    They brought back the notch hiding option, and now everyone is complaining again, because it's not how they imagined it would be. Great. [e]1f602[/e]
  13. Caomhin
    To be honest that's not much. I would definitely suggest a factory reset, may not be the solution, some people say it worked for them, others say it didn't. Would be something you may have to consider.
    Just to add I do have most 3rd party apps optimize Not to run in the background, except those I want notifications from, such as phone, messenger, WhatsApp and a few others on Intelligent Control, the rest are optimized using Optimize, middle setting. If you do set apps to optimize , run to a full charge and recheck your stats once more.
    Or possibly contact OnePlus Support through their website directly to see if they may have a solution.
    If you do contact them, send your stats images and you can use mine as well so they can compare if you wish, or just point them to this comments conversation.
    I have posted my Battery stats for reference taken just now . However I didn't have to Factory reset at any point. On OP6T, I have Upgraded on each stage, but used full sized updates each time. Not incremental, just for reference.
  14. brmbjn
    Gingerbread Dec 18, 2019
  15. NodePoint , via OnePlus 6T Midnight Black , Dec 18, 2019 :
    I used the system update utility that comes with OxygenOS to download the OTA. It does show the change log. It just never lists the features in the other section of the application that is specifically for mentioning features. Not even on stable back on Pie.
  16. Laxmiraj066
    Donut Dec 18, 2019
    Laxmiraj066 , via OnePlus 6T , Dec 18, 2019 :
    I just remembering the Windows phone 10 OS by this Beta builds.. Windows also released windows 10 OS stable with too many bugs, after too many Beta programs. OnePlus also doing the same with OP 6 series, I am unable to understand why OP team struggles to program a stabled version of updated OS for its 6 & 6T devices.. it should be better atleast if they provide latest security patches for their customers,so that they can feel like they are using latest OS in their devices.I hope OP team will never give up to provide the same.
    S1572791689825 likes this.
  17. Nadeem2601
    Donut Dec 18, 2019
  18. PrakarshX
    PrakarshX , via OnePlus 6 , Dec 18, 2019 :
    enjoy your pixel 4. haaaaaahaahahahhaaaaaaa
    C1580688002931 likes this.
