135
OxygenOS Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo
    KitKat Oct 12, 2019
    Swejuggalo , Oct 12, 2019 :
    To 10.0.1 or to downgrade 9?
  2. DineshPoloju
    Cupcake Oct 12, 2019
  3. Covrivov
    Gingerbread Oct 12, 2019
  4. Swejuggalo
    KitKat Oct 12, 2019
    Easiest according to me is to install the app Oxygen Updater. You can look up a link to full update too ofcource if you prefer that. Then do a local update. If you manually download them from a link you need to move the file to local storage and rename it if it's called anything else than .zip. But since you are on beta you probably know that already.
    If you choose Oxygen Updater all you need to do is to configure it with advanced mode and set it to your device and full stable update in the settings. Download and then local upgrade.
    Full download links usually end up in any of the sources here.
    Direct link to post: https://forums.oneplus.com/threads/...o-and-oneplus-7.1117547/page-12#post-20889538
    Due to direct link sucks in community app here is the bitly link: http://bit.ly/2Bb5AbH
  5. MelvinAbes
    MelvinAbes , Oct 12, 2019 :
    no it's not hardware dependant. and only difference between SD855 and SD855+ is that 855+ is overclocked (That too very minimal). It's a software update that OnePlus will push for macro mode
  6. MelvinAbes
    abhilash_saikia
    Hi @akks, good morning!
    Macro mode in the 7T Series is due to special hardware enhancement.
    So, I don't think 7 Series would get Macro mode. @Manu J. ?​
    the 7T has an inferior set of camera sensor than the 7 pro when it comes to telephoto for example. The 7T does not have 3x optical zoom. The 7T has 2ish something
  7. Swejuggalo
    KitKat Oct 12, 2019
    In 7T Pro case the laser autofocus is a bit different. But I doubt its that different to make it impossible to use on 7 Pro. Only time will tell.
    The differance is greater between 7 and 7T though.
  8. MelvinAbes
    was talking about the 7T not the 7T pro. The 7T pro seems to have a TOF sensor
  9. Z1569248468802
  10. nitramcek
    Ice Cream Sandwich Oct 12, 2019
    nitramcek , Oct 12, 2019 :
    I have it too and I'm not even near India.
    I had to wipe the device because I had reboot ever minute or two. But the strange thing is, that I had installed OB about 5 hours and was good and then it started and nothing helped. I hope now will be ok.
  11. gianmar1a
    gianmar1a , via OnePlus 7 , Oct 12, 2019 :
    How do I downgrade from beta 3 to pie ? ( I want the stable version of Android 10 ) Local upgrade method doesn't work. ( OnePlus 7 )
  12. Swejuggalo
    KitKat Oct 12, 2019
  13. Swejuggalo
    KitKat Oct 12, 2019
    Used VPN or something?
  14. MARKX_0406
    Froyo Oct 12, 2019
    MARKX_0406 , via OnePlus 7 Pro , Oct 12, 2019 :
    nitramcek
    I had to wipe the device because I had reboot ever minute or two. But the strange thing is, that I had installed OB about 5 hours and was good and then it started and nothing helped. I hope now will be ok.​
    I had this problem too. The same its start boot animation after 2-3 minutes from starting. I have done full system reset from stock recovery without erased data (just system settings and apps). Not nice(((
    nitramcek likes this.
  15. L1569486940430
    Donut Oct 12, 2019
    L1569486940430 , Oct 12, 2019 :
    No, 7T pro have the laser autofocus and also in op7 pro but in different position
    Alan_Li_Corzo likes this.
  16. Wartou
    Eclair Oct 12, 2019
    Wartou , via OnePlus 7 Pro , Oct 12, 2019 :
    Weird thing! But I haven't had any issues with it though.
  17. MelvinAbes
    oh okay! :)
  18. sahirhussain
    Honeycomb Oct 12, 2019
  19. Alan_Li_Corzo
