136
OxygenOS Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. W1570954827309
    Cupcake Oct 13, 2019
  2. AhmedAhdach
    Eclair Oct 13, 2019
  3. Swejuggalo
    KitKat Oct 13, 2019
    Swejuggalo , Oct 13, 2019 :
    Hmm... What is the name of the file?
  4. Swejuggalo
    KitKat Oct 13, 2019
    Syd.S likes this.
  5. Calogero69
    Calogero69 , via OnePlus 7 Pro , Oct 13, 2019 :
    good morning to all, I wanted to expose my problem, I am in the last ota beta 3, but I would like to return to the official software unfortunately I can't install the official software and I asked you what procedure I have to follow. thank you so much to all of you
  6. Swejuggalo
    KitKat Oct 13, 2019
    Checked filename? Make sure it's only called *filename*.zip and not jar or something in the end
  7. Raghaw_D
    Eclair Oct 13, 2019
    Raghaw_D , via OnePlus 7 Pro , Oct 13, 2019 :
    If in case Open Beta version is that much stable, why shouldn't we call this as Stable Version?
    You Get it.[e]1f44d[/e]
    Tanaypande likes this.
  8. JJJayKob
    Eclair Oct 13, 2019
    JJJayKob , Oct 13, 2019 :
    stable Android 10 has been out on OP7 series for weeks now ...
  9. JJJayKob
    Eclair Oct 13, 2019
    Thanks for the update but unfortunately there's still one persisting bug that drives me crazy:
    Facebook Messenger notifications don't show up while the screen is locked. vibration and sound are there but there's no horizon light or ambient display light up. Tried to somehow bring it back but even with all the settings being set correctly and chat heads turned of the issue persists. this has been happening since beta 1
  10. A1570902583889
  11. Swejuggalo
    KitKat Oct 13, 2019
    Problem is that some don't understand the way beta works. Some is stuck thinking betas is only pre-release software and stops when stable comes. Here it is a continued path along side of stable, always testing stuff before stable recived them.
  12. Vijen101
  13. JJJayKob
    Eclair Oct 13, 2019
    yeah would be nice if people could read instead of spamming stuff like that for no reason
    raghavg13 likes this.
  14. Swejuggalo
    KitKat Oct 13, 2019
    I would start a trial and error removing one app at a time to make sure it does not a cause the reboot.
    Telegram X for example and possible more apps. Whenever you think you found the app causing it use the feedback tool to report it.
  15. L1570957799421
  16. Swejuggalo
    KitKat Oct 13, 2019
    Sometimes beta can be more stable than stable. Sometimes it's not. More problems can be expected as a standard though. You can't jump back and forward effortlessly. Returning to stable path will wipe the phone.
    When using beta you are expected to accept more issues and be willing to report those issues.
    Raghaw_D likes this.
  17. Swejuggalo
    KitKat Oct 13, 2019
    I guess it will tested in beta channel more at a later point. Currently not available. I believe it existed in OB1 or so. But I'm not sure it worked properly.
  18. Covrivov
    Gingerbread Oct 13, 2019
  19. Swejuggalo
    KitKat Oct 13, 2019
    Downgrade files in one of my posts just above this post I'm replying to. They should work. Brings you down to stable 9 AA. Upgrade back to the stable version you want after that.
    Calogero69 likes this.
  20. MarlonCandace
    Froyo Oct 13, 2019
