138
OxygenOS Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. a_m28
    Ice Cream Sandwich Oct 13, 2019
    a_m28 , via OnePlus 7 , Oct 13, 2019 :
    okay please provide stock apk then for OnePlus 7 share it
  2. JrWriter87
    Donut Oct 13, 2019
    Ake Winther and dubbaYous like this.
  3. Tanaypande
    Donut Oct 13, 2019
    Tanaypande , via OnePlus 7 Pro , Oct 13, 2019 :
    Thanks..
  4. F1559836363270
    Cupcake Oct 13, 2019
  5. jim.kanaris
    Froyo Oct 13, 2019
  6. AbhilashSaikia
    The Lab - OnePlus 8 Pro Reviewer Oct 13, 2019
    AbhilashSaikia , via OnePlus 7 Pro , Oct 13, 2019 :
    I've read reviews talk about some kind of motor being used.
    A teardown would reveal what's inside. Macro mode, if possible would be a nice addition to the 7 Pro though.
  7. Z1569922132936
  8. ajazs0929
    ajazs0929 , Oct 13, 2019 :
    I have update to beta 3 in that I facing a finger print scanner is not working in apps like iMobile,kotak and others apps. pls fix it this problem at earliest.
  9. mrizwan06
    Eclair Oct 13, 2019
    mrizwan06 , via OnePlus 7 , Oct 13, 2019 :
    Installing now. I hope they've added an option to enable / disable the chin in keyboard layout (Gap between keyboard and phone's chin).
  10. Yashwanth1799
    Froyo Oct 13, 2019
  11. G_Toni_Jerković_uDrY
    Froyo Oct 13, 2019
  12. pavanpv9
    Froyo Oct 13, 2019
    pavanpv9 , via OnePlus 7 Pro , Oct 13, 2019 :
    Applications closes automatically when screen goes lock.
    example when you have opened Chrome browser, and when you leave your screen ideal and when the screen goes sleep and the application will be killed/closed. i have to tap the application again to open..
    is anyone facing same issue, any fix?
  13. Trollerkins , via OnePlus 7 Pro Nebula Blue , Oct 13, 2019 :
    yeah, I'm using it on Ford sync and it seems to work perfectly fine. only issue I'm having is Google assistant seems to not respond to me unless I restart my phone, but this seems to be an issue that could resolve itself if Google update Google assistant.
  14. Nagendradurgam
  15. G_DepressiveDepressions , via OnePlus 7 Pro Almond , Oct 13, 2019 :
    Uhh, nope. 855+ Is literally the same thing as the 855. I remember that there was a macro mode on DP4~ and it worked fine
  16. elanglois
    Lollipop Oct 13, 2019
    elanglois , via OnePlus 7 Pro , Oct 13, 2019 :
    I'm having an issue where on-screen controls stop responding unless I touch my phone. The Android Auto controls will only work for a few seconds afterwards, then I have to touch the phone again.
    Also, Android Auto's theme is impossed on the phone and while it tries to restore the original theme upon unplugging it, it only gets it half right and I have to manually change the theme every time I'm done driving.
    Both of these issues only exist with OOS 10. They were reported with the initial release and they still have not fixed it. I'm really disturbed.
    So ... maybe the Beta is better ?
  17. elanglois
  18. elanglois
    AnySoftKeyboard doesn't have the chin
    mrizwan06 likes this.
  19. Trollerkins , via OnePlus 7 Pro Nebula Blue , Oct 13, 2019 :
    that sucks! I've not run into any of these issues,it may be with specific car brands and such, so I don't know what to say. what brand of car are you using if you don't mind me asking?
  20. elanglois
    A motor???
    abhilash_saikia likes this.
