135
OxygenOS Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. stefal639
    Eclair Oct 14, 2019
    stefal639 , Oct 14, 2019 :
    Someone has encounter a low quality audio in assistant and calls with Bluetooth earplugs?
    I have bullets wireless and the quality of Google assistant and call quality is awful. With oos 9 is much better.
    Trigun123478 likes this.
  2. ShuvraC
    Eclair Oct 14, 2019
  3. count_zero
    Cupcake Oct 14, 2019
    count_zero , Oct 14, 2019 :
    Guys, Smart Display is simply missing for me in Ambien Display settings. Is it like this for everyone?
  4. Happy Hammer
  5. ANABOLIK
  6. AzuLa9713
    Honeycomb Oct 15, 2019
    abheyarora likes this.
  7. GraveDigger176 , via OnePlus 7 Mirror Gray , Oct 15, 2019 :
    don't have this string all fine here on my side, maybe because I have a normal 7 [e]1f601[/e]
  8. caiiiyua
    Cupcake Oct 15, 2019
    caiiiyua , Oct 15, 2019 :
    I was in Android 10 open BETA 2, 2 days ago, yesterday I received the OTA of Open BETA 3, and upgraded, all of the features are working fine except the DRM.
    • Can't play any online streaming content with DRM protection (Widevine for Netflix, etc)
    • After upgrade, the current system version is OP7Pro_O2_BETA_3, but I am using a OP7 instead of OP7 Pro.
    Please do NOT upgrade to BETA 3 if you have not done yet.
  9. Richardreyesgo
    Stylianos_Kalintzis likes this.
  10. O1560407858073
    Donut Oct 15, 2019
    O1560407858073 , via OnePlus 7 , Oct 15, 2019 :
    Is anybody having battery draining issues even if phone is not being used after open beta 3 update? If anybody has solution regarding this battery draining issues other than full resetting the phone, please help.
  11. AndiTheBassman , via OnePlus 7 Pro , Oct 15, 2019 :
    I know it's not the Betas Fault and probably a bug in the app but for some reason my Google App tends to turn black while I'm typing a search. When I close the App and start it again it turns white again. Very strange and a little annoying
    02ferreiravilarl likes this.
  12. Freakazoidberg
    Donut Oct 15, 2019
    Freakazoidberg , Oct 15, 2019 :
    Bugs I've found till now:
    - 'back' gesture for music on inactive screen won't repeat the actual song anymore
    - tapping on the bottom of the screen (homebutton is just a gesture, not visible) closes Keyboard
    Improvements I'd suggest:
    - please remove the widget titles on the shelf. Needs to much space, looks shit
    - dark theme but white notifications possible?
  13. RohanLuktuke
    Trigun123478 and ivanalhilali like this.
  14. c3drik67
    Froyo Oct 15, 2019
    c3drik67 , Oct 15, 2019 :
    It's because you use the 3 button on screeen if you use the navigation gesture you see the space at the bottom.
  15. Hawker29
    Hawker29 , Oct 15, 2019 :
    yeah there is a small problem i found in my device OnePlus 7pro after upgrading to beta 3 update. My mobile hangs while an incoming call comes and can't able to attend or able to cut the call until the caller himself cuts the call.thats an major problem in beta 3 update iam still facing it .
  16. asrarpipawala
  17. Hawker29
    for me everything thing in this Beta 3 update is working good. But there is a problem in my device OnePlus 7pro after upgrading to beta 3 update. My mobile hangs while an incoming call comes and can't able to attend or able to cut the call until the caller himself cuts the call.thats an major problem in beta 3 update iam still facing it . During the hang of the call i can able to use any apps in the device but can't able to attend or able to cut the call.
