136
OxygenOS Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. Wartou
    Eclair Oct 15, 2019
    Wartou , via OnePlus 7 Pro , Oct 15, 2019 :
    Same here
  2. Colday_96
    Froyo Oct 15, 2019
    Colday_96 , via OnePlus 7 , Oct 15, 2019 :
    bugs I have noticed with beta 3:
    - Notification icon shifts to the left depending on how many notifications you have.
    - There seems to be a hi glitch in the recent panel with the corners.
    - Bluetooth is still not as stable as it was on pie
    - Gestures are still a bit buggy at times
    - Sometimes, there is a bit of lag when turning on the screen
    Battery life is a lot better than it was on beta 2. This is also a clean flash.
    Trigun123478 likes this.
  3. m4ss
    Froyo Oct 15, 2019
    m4ss , via OnePlus 7 Pro , Oct 15, 2019 :
    android auto is unusable in this beta3, buttons disappear and can't select anything in the menu.
    please anyone can confirm this major bug or it's only me and another user above that I don't remember the name ?!
    if you have android auto, please can you try with this b3 ?
  4. Zeus89
    Eclair Oct 15, 2019
    Zeus89 , via OnePlus 7 Pro , Oct 15, 2019 :
    It's good overall, I noticed some lag when turning on the screen.
    Suggestions :
    Please allow us to leave the recents by taping on an empty part of the screen like it was in pie. Reaching down to perform the home gesture is uncomfortable in thin big device
  5. gg1+
    Froyo Oct 15, 2019
  6. SeegPlus
    Froyo Oct 15, 2019
    SeegPlus , Oct 15, 2019 :
    Same here. Turning off Gmail notifications helps.
  7. Raghaw_D
    Eclair Oct 15, 2019
    Raghaw_D , via OnePlus 7 Pro , Oct 15, 2019 :
    After installing the OB3, the music system behaves unusually than previous.
    I am listening to download the songs in WYNK Music/ Jio Music/ Spotify. Suddenly some kind of crackle sound is coming in between the song and it stops playing.
    Then after I press the power button and the songs resume.
    Does anyone feel the same? Please let me know.
    RohanLuktuke likes this.
  8. G_Aman_Khan_Zarc
    Cupcake Oct 15, 2019
  9. Crapshit , via OnePlus 7 Pro Nebula Blue , Oct 15, 2019 :
    Can anyone please explain me the difference between Open Beta 3 and Final 10.0.1?
    Both came out on the same day?
    I thought Open Beta 2 was the last Beta for Android 10.
    Or does Beta 3 have new Features compared to 10.0.1?
  10. Joey463
    Honeycomb Oct 15, 2019
    Joey463 , via OnePlus 7 Pro Nebula Blue , Oct 15, 2019 :
    I had a similar bug during beta 2. Every call would hang up after exactly 15 minutes. I was able to ring back and use the phone but without fail it would automatically hang up at the 15 minute mark.
    It's fixed now. But that was annoying when running beta 2
    Hawker29 likes this.
  11. Adrian_1plus
  12. Joey463
    Full system wipe of your phone. If you don't know how to do that, you shouldn't have joined the beta. But read the main post you will find all the information needed
  13. stefal639
    Eclair Oct 15, 2019
    stefal639 , Oct 15, 2019 :
    someone else?
  14. Adrian_1plus
    Adrian_1plus , Oct 15, 2019 :
    Joey463
    Full system wipe of your phone. If you don't know how to do that, you shouldn't have joined the beta. But read the main post you will find all the information needed​
    I just want to go back to stable Android 10 even with all wipe data. please help me how to do it? Three was no problem with beta2. But i can't do it with beta 3
  15. Joey463
    I have no sympathy for anyone that does this. But like I said all the information is in the post. I'm not adding anymore to this topic.
  16. KL4US_199
    Froyo Oct 15, 2019
  17. Adrian_1plus
    Is written: Moving back to the official oraz Path from the beta Path will require a full install and clean flash.
    OK, wipe all data and flash. Flash what?
  18. Zeus89 likes this.
  19. Adrian_1plus
    "The version of the selected package od lower than the current system. To avoid a startup problem it os not recommended to switch to a lower version"
    i'm trying to install Oxygen 10.0.1
  20. Swejuggalo
    KitKat Oct 15, 2019
