136
OxygenOS Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. Fererio
    Froyo Oct 16, 2019
    Fererio , via OnePlus 7 , Oct 16, 2019 :
    you should rollback to pie and then you have to update to stable build
    jim.kanaris likes this.
  2. Uxullko
    Cupcake Oct 16, 2019
  3. DanishMohd
    DanishMohd , via OnePlus 7 Pro , Oct 16, 2019 :
    Hi,
    i am facing issue with OB 3 as i had updated my One plus 7 pro, my earphones are not working now amd many more bugs like hanging while browsing in slow connection. i want to go back with stable os10.0 please guide me how i can do that.
  4. Gauravk93
    Gingerbread Oct 16, 2019
  5. Sanchitmeena
    Froyo Oct 16, 2019
    Sanchitmeena , via OnePlus 7 , Oct 16, 2019 :
    Guyz , a general question. If I download one plus 7t pro McLaren icon pack in my one plus 7, will it affect in further updates of my normal one plus default icon packs ?
  6. dhopmans
    Honeycomb Oct 16, 2019
    dhopmans , Oct 16, 2019 :
    No it won't.
  7. jithendranara
    Eclair Oct 16, 2019
  8. m4ss
    Froyo Oct 16, 2019
    m4ss , via OnePlus 7 Pro , Oct 16, 2019 :
    can i have some feedbacks about android auto ?
    mine with this build is unusable, buttons disappear and can't click/select nothing inside menu !
    beta2 was ok.
    please someone have android auto ?
    I'm thinking to switch to "stable" channel
  9. Rajkumar rk
  10. Anonymous_AK , via OnePlus 7 Mirror Gray , Oct 16, 2019 :
    I have received OB3 update for oneplus 7, I want to roll back to stabel releases here after, But official stable rom is available only for 9 version when I try to install it is showing error stating I can't downgrade
  11. Bauber
    Donut Oct 16, 2019
  12. Swejuggalo
    Lollipop Oct 16, 2019
    Swejuggalo , Oct 16, 2019 :
    Would be great if you send the error report in with the feedback tool in community app with screenshots and logs.
    I would gladly help out reporting. I just need a free car that supports it sent to me [e]1f609[/e]
  13. Swejuggalo
    Scroll abit higher up and you see my posts about this topic
  14. Swejuggalo
    Oxygen Updater, Telegram channel are some options.
    Also at the official homepage link from the first post here...
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
  15. m4ss
    Froyo Oct 16, 2019
    screenshot are impossibile, the problem occur on the external display of the car.
    i could send logs, but i would simply understand if this problem affect all user of beta3.
  16. N1562686905653
    N1562686905653 , Oct 16, 2019 :
    I have a question about the One Plus 7 camera. the colours appear extra saturated especially the greens. any tips on how this can be rectified please
  17. FIROZ77
    Eclair Oct 16, 2019
  18. yakko
    yakko , via OnePlus 7 , Oct 16, 2019 :
    Hello guys!
    With this OB3 I found these issues for the moment:
    - the Shelf menu didn't work well. It froze on the swipe up or down.
    - didn't find the Pocket mode
    - the Adaptive brightness it still works bed. On powerful light it dims to low.
    That's it for the moment.
    IL will wait for new release, maybe these problems will be solved.
    Best Regards!
  19. Tylor Daniel
    Tylor Daniel , Oct 16, 2019 :
    still didn't fix the issue with Bluetooth earbuds completely
    I own Samsung earbuds and when they are connected and I get a call the phone turns off
    please look into this it's the last problem I have with this update
