136
OxygenOS Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. a_m28
    Ice Cream Sandwich Oct 17, 2019
    a_m28 , via OnePlus 7 , Oct 17, 2019 :
    which screen protector have u applied on your regular OnePlus 7 ?? please share can i use it without screen protector? please share your thoughts
  2. O1537877197296
    Cupcake Oct 17, 2019
    gitanshbindal and snabb like this.
  3. Swejuggalo
    KitKat Oct 17, 2019
    Swejuggalo , Oct 17, 2019 :
    Since this will wipe your phone... You might actually be better of with trying a factory reset and don't recover any data other then media files. If you still prefer stable over beta consider a fresh start without automatically install all apps and recover app data that might have caused your issues to begin with.
    Link to rollback and info below.
    Direct link to post: https://forums.oneplus.com/threads/...o-and-oneplus-7.1117547/page-12#post-20889538
    Due to direct link sucks in community app here is the bitly link: http://bit.ly/2Bb5AbH
    I'm very happy with beta 3.
    Getting close to 140h up time with no strange behavior. Up 9.5h SOT with 17% left on a charge. (no tweaks)
    Backups can sure be nice... But sometimes it can be like changing oil in your car but reuse the oil filter and a random amount of old oil. And I really hate that [e]1f609[/e]
  4. C1508158874911
    Froyo Oct 17, 2019
    C1508158874911 , via OnePlus 7 , Oct 17, 2019 :
    I m in Beta3 of my OnePlus7.
    My two fingers r registered but when I try for third finger registration suddenly pop-up comes of app close[e]1f631[/e]
    Anybody faced that after Beta3 on OnePlus7?
  5. H1569911053068
  6. wgomez90
    wgomez90 , Oct 17, 2019 :
    I've received the OTA update to OPB3 and unfortunately after the install completed my phone began having random reboots - I cannot pinpoint exactly what causes it though I've managed to delay the time between reboots by holding volume up + power for 10-15s and when it comes back I turn it off for 5-10mins. With this method, the most I've gotten it to not reboot is maybe 5-6hrs
    I've also wiped the cache but it did not fix my issue.
    I am now attempting a factory reset of system data - if that doesn't work I will do a full wipe.
    I managed to do a few log captures. Can someone advise on what the best way will be to report these? The support chat method just doesn't seem worth the time....
  7. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 17, 2019 :
    Use the feedback tool to report this issue. It exist within the community app.
    If they need more info they will contact you via PM.
    They often return with things like this. So you could do that right from the start too.
    We would like to take this further and would request you to share with us the device name and device logs at the time of issue occurrence. Be rest assured; your data would be secure.
    1. How Often you face this issue(probability)in a day?
    2. Does this issue persist in the last update?
    Steps for logs:
    1. Open dialer -> Dial *#800# -> Open ‘oneplus Logkit’ and click delete history logs
    2. Check ‘Move logs path to built-in SD card’andand check 'network 'Tcpdump log'
    3. Check ‘save log’ and click cancel
    4. go back to home screen and reproduce the issue that you are facing-> Once its Reproduced capture screenshot to note the timestamp.
    5. Again, dial *#800 # and Open ‘oneplus Logkit’-> Open other log info
    6. Click 'get bugreport info' and wait for 2 minutes(until it’s greyed out)
    7. Go back uncheck ‘save log’ and all other enabled option
    8. go back to home screen. Open file Manager from app drawer -> storage -> internal storage
    9. Search for Oem_log Folder ->long press it-> Click three dots on the top Right corner -> compress it
    10. Find oem_log.zip at the bottom, long press it again-> Click three dots on top Right corner -> Click Share -> Share via Drive along with the screenshot and Provide the link here
    Note:
    1. Keep the drive link open.
    2. After sharing the link, please delete the Oem_log file and folder from your Device or it will occupy more Storage Space.
  8. Lunatico
    Jelly Bean Oct 17, 2019
    Lunatico , Oct 17, 2019 :
    Yeah, its awe full, i tried to make a thread and raise awareness about the issue but some smart-*** MOD thought it was a good idea to close the thread.
  9. SOVANM
    Eclair Oct 17, 2019
    SOVANM , Oct 17, 2019 :
    By anychance can OnePlus add various editing options for gallery pictures. Advance editing tool, video editors or gif creator. those are all basic softwares one can find in samsung phone allowing you to create beutiful post processing effects.
  10. SOVANM
    Eclair Oct 17, 2019
    though oneplus7 pro has a edge screen it could have lunched edge feature as found in samsung S8, s9,S10 devices. those hovers really helps to redirect to desired activities quickly. is the team working on having the feature update in near OS updates. if not kindly have a look on the feature, that would be a great treat for peoples who like to switch between various activities in a phone.
  11. gen_iroh
  12. JNiemi likes this.
  13. GITANSHBIN
    Eclair Oct 17, 2019
    GITANSHBIN , Oct 17, 2019 :
    Hi, my oneplus 7 pro is on open beta3 and its reboot itself just after i unlock, it doesn't give me even a minute. If i don't unlock the phone doesn't reboot and stays there. Any workaround or fix?
  14. ronnyhawks
    ronnyhawks , Oct 17, 2019 :
    No it doesn't lol. you dirty flashed so you need to wipe all data and start from scratch. user error. not anything else
  15. JohnMcClain
  16. F1571356743816
    Cupcake Oct 18, 2019
  17. Raghaw_D
    Eclair Oct 18, 2019
    Raghaw_D , via OnePlus 7 Pro , Oct 18, 2019 :
    True Indeed.[e]1f44d[/e]
  18. dhopmans
    Honeycomb Oct 18, 2019
    dhopmans , Oct 18, 2019 :
    Now your phone is worthless.... What should we do??
  19. AzuLa9713
    Covrivov likes this.
