136
OxygenOS Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    Please use the feedback tool to report this issue. It exist within the community app.
    If they need more info they will contact you via PM.
    Many does not know how to do this so if you know it already I hope someone else will be aware about it
  2. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    What music app and what battery settings on the app?
  3. FIROZ77
    Eclair Oct 18, 2019
  4. vriesdejoop
    Ice Cream Sandwich Oct 18, 2019
    JNiemi likes this.
  5. warren_dewz
    Eclair Oct 18, 2019
    warren_dewz , via OnePlus 7 Pro , Oct 18, 2019 :
    Hi, thanks for responding. Spotify music. What do you mean by battery settings?
  6. warren_dewz
    Eclair Oct 18, 2019
  7. warren_dewz
    Eclair Oct 18, 2019
  8. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    Try the don't optimize setting on Spotify. You could also check what kind of codex it uses. And if it applies only to some devices (SBC devices or Apt-X enabled devices for example). Visible in developers options.
  9. timwan
    Cupcake Oct 18, 2019
    timwan , Oct 18, 2019 :
    Problem solved!!
    vriesdejoop likes this.
  10. warren_dewz
    Eclair Oct 18, 2019
    Thanks the don't optimize seems to have worked.
  11. vriesdejoop
    vriesdejoop , via OnePlus 7 Pro Nebula Blue , Oct 18, 2019 :
    good to hear..... until now all the reboots had to do with alarm sounds. I did not have any reboots until now, don't understand yet why some don't have these problems....
  12. T1564120032126
    T1564120032126 , Oct 18, 2019 :
    I updated my OnePlus 7 to Android 10 ...now I am noticing a.bug like...the push notifications content is displaying even if I didn't unlock my app
  13. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    BTW I never heard of those Apt-X variants. Are they used for some special hardware you got?
    Regular Apt-X works great though.
  14. I1548108228146
    I1548108228146 , via OnePlus 7 Pro , Oct 18, 2019 :
    Hey guys!
    I'd like to downgrade my phone form the Beta 3 of OOS to the stable One. I already tried to download the stable OS file from the official support, but I can't use the "upgrade" method to downgrade.
    What should I do?
  15. Maximilian Gaedig
    Gingerbread Oct 18, 2019
    Maximilian Gaedig , via OnePlus 7 Pro , Oct 18, 2019 :
    my op 7 pro is rebooting randomly after the update, tried dirty flashing beta 2 with twrp but it booted me back to beta 3 :/
    (I have Root)
    Would appreciate any help :)
    Yes I understand it's a Beta :)
  16. N3D
    Eclair Oct 18, 2019
  17. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    Seems to be a common issue. I did a factory reset at OB1 and have not used any backed up data at all. Even have the Google backup funtion permanently off.
    All the things that matter is on Onedrive anyway (media files). Everything is rock solid on beta 3. 160h+ without reboot with no hickups at all.
