135
OxygenOS Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    Seems to be a common issue. I did a factory reset at OB1 and have not used any backed up data at all. Even have the Google backup funtion permanently off.
    All the things that matter is on Onedrive anyway (media files). Everything is rock solid on beta 3. 160h+ without reboot with no hickups at all.
  2. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    BTW, since there is A/B system you may need to change active slot or something. I stopped rooting ages ago...
    Anyway...Android 10 seems very picky about old data so far. I seem to have avoided basically every bug most other have had, probably thanks to my hate of backups [e]1f609[/e]
    JrWriter87 and XRaptor29 like this.
  3. Maximilian Gaedig
    Gingerbread Oct 18, 2019
  4. Maximilian Gaedig
    Maximilian Gaedig , via OnePlus 7 Pro , Oct 18, 2019 :
    I tried tinkering with the A/B system but I didn't work unfortunately :/
  5. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    Think I read something about dirty flash it over beta and wipe dalvik (and the basic deactivated magisk modules and reflash of twrp and all that you normally do when upgrading). Many of the issues beta 3 has seems to apply to stable though.
    Not so sure about the reboot issue though.
    Maximilian Gaedig likes this.
  6. Maximilian Gaedig likes this.
  7. Cervantes
    Lollipop Moderator Oct 18, 2019
    Cervantes , Oct 18, 2019 :
    Hi
    Please, you read the first post
    *"The beta thread or update thread is a thread of questions and/or commentary"*
    Please, You can use the search engine before opening a new thread
    Thread merged
  8. suva_ee1
    Cupcake Oct 18, 2019
  9. Maximilian Gaedig
    Yayy it worked !! am on stable now :) Thank you!
    Swejuggalo likes this.
  10. Adi_2019
    Eclair Oct 18, 2019
  11. Adi_2019
    Eclair Oct 18, 2019
    Adi_2019 , via OnePlus 7 , Oct 18, 2019 :
    yes that's what I mean. how could they remove an already existing feature in "upgrade"!! what a blunder!
  12. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 18, 2019 :
    Changes in the base OS would probably be the reason. If it returns in any form it would need an adoption to Android 10.
  13. podagee
    podagee , via OnePlus 7 Pro , Oct 18, 2019 :
    I haven't experienced any bugs and running OB3 for a few days now. I am also using a custom kernel with no issues.
  14. suryan221
    suryan221 , Oct 18, 2019 :
    Battery life has been really bad with this build . Idly battery drain is almost 5% a hour. which is bad
  15. L1515254752403
  16. GraveDigger176 , via OnePlus 7 Mirror Gray , Oct 18, 2019 :
    That's exactly also my point now, my last phone with root was the Google Nexus 6. Since then I had a OnePlus 5, 6t and now the 7. On all three phones root is nonsense, because they run more than fast and stable on OOS. I never do a backup because is also nonsense, I save all my important files on a cloud. I always flash every OpenBeta with complete clean flash with wipe everything in stock recovery. I never have any reboot or one of the other reported bugs.
    If the user with reboots or any other bugs want a perfect running OnePlus 7 with OpenBeta 3, they should do a clean flash, simple as that [e]1f601[/e][e]1f602[/e][e]1f44d[/e]
  17. nikhpillai
    Cupcake Oct 19, 2019
    nikhpillai , Oct 19, 2019 :
    r u experiencing tone change when connecting?
  18. elanglois
    Lollipop Oct 19, 2019
    elanglois , via OnePlus 7 Pro , Oct 19, 2019 :
    That doesn't bother me. It doesn't go back sometimes. And I can't touch buttons on the Android auto screen without playing with my phone first
  19. H1571377288293
