135
OxygenOS Open Beta 3 for the OnePlus 7 and OnePlus 7 Pro
  1. nikhpillai
    Cupcake Oct 19, 2019
    nikhpillai , Oct 19, 2019 :
    sorry brother, i didn't have that issue.
  2. elanglois
    Lollipop Oct 19, 2019
    elanglois , via OnePlus 7 Pro , Oct 19, 2019 :
    Oneplus has been no help. Maybe its because I'm on stable? You are on beta right? Maybe I need to switch.
  3. elanglois
    Georgeoneplus7pro likes this.
  4. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 19, 2019 :
    There is a link to Oneplus homepage on first post. It should show you beta too
  5. elanglois
    You should check before making claims. If the first post had a link, I wouldn't have needed to ask!
  6. DizzyDaz
    DizzyDaz , via OnePlus 7 Pro , Oct 19, 2019 :
    I'm currently running Android 10 beta 3
    can not update to new 10.1 stable release
    can anyone help me downgrade / rollback to stable build so I can upgrade ?
    or if I wait it out ... will I get the stable 10.1 build naturally like any other update ?
    or will I have to get out of beta to update ?
    any help would be appreciated [e]270c[/e]️
  7. DizzyDaz
  8. B_Wrath
    Marshmallow Oct 19, 2019
    B_Wrath , Oct 19, 2019 :
    All beta related queries must be done on the beta thread.
    That is expected out of any competent beta tester.
    Don't create redundant threads.
    JrWriter87 likes this.
  9. DizzyDaz
    can anyone please help me get out of beta ?
    I want to update to stable 10.1
    but don't know how to revert back ? will a factory reset do the job ?
    or can I just downgrade to pie again
    any help appreciated !!!
  10. DizzyDaz
    well I'm new to Android & one plus beta ... no need to be a smart arse & better of asking first if I knew about the official thread instead of assuming I should automatically know ?
    anyways I posted in ' official thread ' your problem is solved .
  11. N1533583631881
    N1533583631881 , Oct 19, 2019 :
    Updated to Android 10, can't easily access my hidden apps, Banking apps cannot work because they detect 'rooted' device. My phone was working perfectly well before the update
  12. B_Wrath
    You installed a beta. You are supposed to know.
  13. J1508070026278
    Gingerbread Oct 19, 2019
  14. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 19, 2019 :
    From within community app this is what I see.
    Alternative sources exists of course. The site gives different results depending of browser or app of some strange reason. So it's possible to get a site without beta links
    Here is a Telegram channel that posts both betas and stables.
    OnePlus[e]2122[/e]
    Everything OnePlus #NeverSettle
    Not endorsed by OnePlus
    https://t.me/OnePlus
    Covrivov likes this.
  15. Cervantes
    Lollipop Moderator Oct 19, 2019
    Cervantes , Oct 19, 2019 :
    Hi
    Please You read the first post
    *"The beta thread is a thread of questions and/or commentary"*
    Thread merged
  16. Nishad sk
    Donut Oct 19, 2019
    venkyred20052 likes this.
  17. darkarvan
  18. Swejuggalo , via OnePlus 7 Pro Mirror Gray , Oct 19, 2019 :
    I use it often. Never a problem. Some have issues though. But that is either a bank issue or a need of clean the app data or something.
  19. ssk0101
    Froyo Oct 19, 2019
    ssk0101 , via OnePlus 7 , Oct 19, 2019 :
    After using the Open Beta 3 for 8-10 days i came across the following issues
    1. Instagram closes as it is unlocked using a fingerprint
    2. Youtube videos freeze in between and the app needs to be restarted to keep going
    3 Mobile data takes longer time to switch from wifi
    4. Still no notch hiding feature
    5 7t wallpapers won't work.
