312
OxygenOS Open Beta 30 for the OnePlus 3 and 21 for the OnePlus 3T
Thread Status:
Not open for further replies.
  1. Yannis Neris
    Ice Cream Sandwich Jan 27, 2018
    Yannis Neris , Jan 27, 2018 :
    Did you install OB 30 on OP3T?....
  2. yogeshme60
    Cupcake Jan 27, 2018
  3. Deactivated User
    Jan 27, 2018
  4. Deactivated User
    Jan 27, 2018
  5. sometheway
    sometheway , Jan 27, 2018 :
    I just updated for the beta 21, the face I'd unlock, still needs to swipe up to unlock, what a shame still....
  6. Fast_and_Curious
    Jelly Bean Jan 27, 2018
    Fast_and_Curious , Jan 27, 2018 :
    Thanks a lot! I have turned it on for one phone app.. will check and let you know.
  7. Sun90
    Starting Point Expert Community Expert Jan 27, 2018
    Sun90 , Jan 27, 2018 :
    Not all Beta feature gets into the official build as long as they are stable enough.
  8. Kushal Rajbhandari
    Donut Jan 27, 2018
    Kushal Rajbhandari , Jan 27, 2018 :
    I flashed the OB 30 today and set it up with the usual setup wizard, face unlock, PIN code and everything. Everything works fine until I try to add fingerprint from under the security settings where it says my PIN code is wrong. I can reboot the phone and use the same code to unlock it and even unlock the phone in recovery mode but I cannot use the code to add a fingerprint or turn off face unlock or do anything from within security settings that requires a PIN code.
    Has anyone else come across a similar if not the same problem on the OB 30 or previous versions? Thanks!
  9. Jmilu76
    Froyo Jan 27, 2018
    Jmilu76 , Jan 27, 2018 :
    I probed and it is working to me.
  10. Kushal Rajbhandari
    Donut Jan 27, 2018
  11. Jmilu76
    Froyo Jan 27, 2018
    Wow
    I think you found a bug...
    Let I just say, I can't reproduce this... Hmm interesting...
  12. Kushal Rajbhandari
    Donut Jan 27, 2018
  13. Deactivated User
    Jan 27, 2018
  14. Q1517078593696
  15. Jmilu76
    Froyo Jan 27, 2018
    Face lock isn't an app... It is a setting at the security section...
    S_T_A_R likes this.
  16. fdroko
    fdroko , Jan 27, 2018 :
    If you knew how to read, you would understand that it is a function and not an app :rolleyes:
    ghostofcain, Sun90, S_T_A_R and 2 others like this.
  17. Q1517078593696
    Q1517078593696 , Jan 27, 2018 :
    OK! thank you so much for informing me.....
    SIR!!!
  18. asasione
    asasione , Jan 27, 2018 :
    That's interesting, can't reproduce it either but you'll probably need to send logs
    Sun90 likes this.
  19. Q1517078593696
  20. angussmith1987@g
    angussmith1987@g , Jan 27, 2018 :
    Hi can u tell me this update require Root ??
