80
OxygenOS Open Beta 31 for the OnePlus 5 and Open Beta 29 for OnePlus 5T
  1. Aziz_Amin_Oneplus
    Jelly Bean May 2, 2019
    Aziz_Amin_Oneplus , May 2, 2019 :
    W1543518891242
    bro
    i think u dont understand what I said
    last security patch was of jan
    now it is for april
    so.how many months has it been ?​
    That is Security patch, you refer to waiting for 4 months means you went pass 4 months for an update which I refer, Security patch is not related to the features you said above and that are whole different things.
  2. W1543518891242
    Cupcake May 2, 2019
    W1543518891242 , May 2, 2019 :
    i was refering to everything.
    204mb has been the smallest till date
    recent update doesnt have a major chNge in anything
  3. Aziz_Amin_Oneplus
    204 MB is incremental update, go in feedback option if you want more features.
    sawrub likes this.
  4. shubhamdsingh
    Froyo May 2, 2019
  5. Aziz_Amin_Oneplus
  6. shubhamdsingh
    Froyo May 2, 2019
    shubhamdsingh , May 2, 2019 :
    to be honest I didn't !!
  7. Aziz_Amin_Oneplus
    It look good but if they could make an different option for "checking for updates" then it would have been more good.
  8. shubhamdsingh
    Froyo May 2, 2019
    agree[e]1f44d[/e]
  9. Aziz_Amin_Oneplus
    Another thing they have changed is the Auto Rotate icon on quick settings, previous icon looked and went with the rest of the icons.
  10. Deactivated User
    May 2, 2019
    metalhead079 likes this.
  11. metalhead079
    Froyo May 3, 2019
    metalhead079 , May 3, 2019 :
    I kinda posted same comment as you. Guess what? My comment was deleted by the moderator.
    Deactivated User likes this.
  12. aneeshkhanna
    Cupcake May 3, 2019
    aneeshkhanna , May 3, 2019 :
    hi everyone. does anyone else have the issue of speedial not working for most contacts? after last two updates it works for 2 out of 10 contacts. I tried to erase cache but the problem still persists. any suggestions??
  13. aneeshkhanna
    Cupcake May 3, 2019
    hi. I have been having an issue with my one plus 5 in the previous 2 beta updates. the speedial doesn't seem to work for majority of contacts. it works for 2 out for 10 contacts. I have tried erasing the cache also but it doesn't work. any suggestions??
  14. joncharmed93
    Froyo May 3, 2019
  15. R1512274214831
    Gingerbread May 3, 2019
    R1512274214831 , May 3, 2019 :
    Nope for me it's working but when. you dial screen is minimizing
  16. H1545889999285
    Cupcake May 3, 2019
  17. Yash_Redekar_Iskk
    Cupcake May 3, 2019
    Yash_Redekar_Iskk , May 3, 2019 :
    please send me oxygen os link for one plus 5T now i am on stable update i want to install oxygen os please anyone help me.
  18. SP3NGL3R
    SP3NGL3R , May 3, 2019 :
    Um. You're on stable. Just wait for the stable update. This is the unstable channel (aka, Beta).
    If you want to switch to the Beta (unstable by assumption) then it's a simple update you can download directly from the support site ... With instructions. But. Take a full backup of everything you think you'll need. Because last time I went Beta (probably beta1) it erased my phone. Which, it should do for proper testing.
  19. SP3NGL3R
    PS I may have misunderstood. If you've done nothing to your 5T, you have Oxygen OS already. Just not the Beta version. I suggest you just stay where you are, check for updates normally and enjoy. This Beta area can be VERY bad for your experience, if you're not experienced with development builds. Just stay on stable channel
    PokiX and Mr_Cyrox like this.
  20. Kuma76
    Donut May 3, 2019
    Kuma76 , May 3, 2019 :
    Hi there,
    since I updated to Open Beta 31 my GPS is not working in any app (TomTom Go, Waze, Google Maps...)
    does anyone have the same issue?
    any way to fix it?
    thanks!!!
