80
OxygenOS Open Beta 31 for the OnePlus 5 and Open Beta 29 for OnePlus 5T
  1. Chuck_James
    Honeycomb May 1, 2019
    Chuck_James , May 1, 2019 :
    very nice oil painting effect
    Rishabh.bhoma1 likes this.
  2. Chuck_James
    Yeah, post-processing sucks since Pie upgrade.
  3. paulomodesto
    Ice Cream Sandwich May 1, 2019
    paulomodesto , May 1, 2019 :
    Totally lost focus, I was quite still.
    Then I use the long press on Finger Print Sensor to take the photo to have no shake and the image was simple perfect, but after the picture was taken it come was like this.
  4. L1524844146326
    Gingerbread May 1, 2019
    L1524844146326 , May 1, 2019 :
    my camera result is very good after this update.cemera result is at very best with best realistic view.may be u should clear cache and try again.
    noted.my devices is rooted with magisk and install a magisk module for camera called OnePlus 5t longshoot PNG.
    Rakshit_Patil likes this.
  5. san94fbr
    san94fbr , May 1, 2019 :
    first fix below problem when OnePlus sending product into market like type c headphones it has to support fully without any issues.
    when using c type headphones with OTG enabled as suggested by OnePlus, During calls I am able to hear the other person's voice but after every 5 min the other person can't hear me. 3.5 mm jack headphones and without headphones,again its works fine without any issues on my OnePlus 5T.
  6. aneeshkhanna
    Cupcake May 1, 2019
    aneeshkhanna , May 1, 2019 :
    hi all. I updated my one plus 5 and the speedial isn't working. it works in 2 out of 10 contacts. have tried to erase the cache also but still the problem persists. have been facing this issue since last 2 updates. any suggestions?
  7. shahbaj alam
    dareknowak likes this.
  8. Berk.Catal
    Berk.Catal , May 1, 2019 :
    nope, I clear install and lag is going. fixed issues.
  9. shahbaj alam
    shahbaj alam , May 1, 2019 :
    i don't know, but i faced that issue
  10. Berk.Catal
    Please wiping phone. if clear install lag issues fixed.
    shahbaj alam likes this.
  11. shahbaj alam
    Long press and hold at any free space of your home screen, now click home settings, now turn on the toggle named "swipe down".
    you are done.
  12. G_Rohit_Sarna
    G_Rohit_Sarna , May 1, 2019 :
    shahbaj alam
    you are done.​
    thanx for Ur help brother I did it way back in 2017 and did it again today as well and did it again today cleared the launcher cache now I will clear the cache from bootloader my last hope
  13. shahbaj alam
    clearing cache might help. try it
  14. G_Parthesh_Jadhav_TNSs
  15. Khems91
    Khems91 , May 1, 2019 :
    Display network speed is now looking weird, old style was Awesome !!
    edcassaro likes this.
  16. edcassaro
    Eclair May 1, 2019
    edcassaro , May 1, 2019 :
    they're aren't completely gone. lags still occurs. it's sad [e]1f622[/e]
  17. Berk.Catal
    Nope, I'm clear install and lag is going.
  18. Khems91
    Definitely there is lag in UI but less than stock, it means they fixed it but not completely fixed.
    some users are claiming here that they don't feel any lag, maybe they can't notice it.
    Rakshit_Patil and edcassaro like this.
  19. Jayant123456
    Cupcake May 1, 2019
  20. Ana Guerra
    Eclair May 1, 2019
    Ana Guerra , May 1, 2019 :
    Does anyone have experienced problems with battery in this beta? to see if I download it. [e]1f601[/e]
