167
OxygenOS Open Beta 35 for the OnePlus 5 and Open Beta 33 for OnePlus 5T
  1. udayachendur
    Honeycomb Jun 29, 2019
    udayachendur , Jun 29, 2019 :
    Till now I thought that they mentioned OTA, but now I start to doubt it.
    They must have mentioned about the zip for reverting back manually.
  2. Mr_Cyrox
    KitKat Jun 29, 2019
    Mr_Cyrox , Jun 29, 2019 :
    Then it's the same like us now...
    Meh
  3. udayachendur
  4. pvtjoker25
    Cupcake Jun 29, 2019
    pvtjoker25 , Jun 29, 2019 :
    Hello guys.
    I'm on op5t_o2_beta_23 and would like to move directly to beta 33 which is the last one. Is it okay to download the latest upgrade from oneplus website install it?
    Please note that I keep getting " Update Fail" after a reboot for the last 10 (i suppose) beta versions when I try to update it from system updates (Sometimes it says " Continue to download" after 100% and restarts the download from 0% as per screenshot and the cycle continues).
    Thanks in advance, any help would be appreciated.
  5. M1524400320494
  6. ninja123456
    Ice Cream Sandwich Jun 29, 2019
  7. Jeff_33
    Gingerbread Jun 29, 2019
  8. ninja123456
  9. ashu9211
    Donut Jun 29, 2019
  10. shahbaj alam
    shahbaj alam , Jun 29, 2019 :
    strange!!! if you are on open beta,you will automatically get latest open beta 33 via OTA.
  11. pvtjoker25
    hi.. yes that is true.. but as i mentioned before after i download my update from system updates and reboot the update fails.
  12. shahbaj alam
    well, download any other version of open beta for your 5T, then paste it in root folder of your internal storage. then flash it. hope it will work.. you can find open beta rom by searching on Google. I'm trying to give you link . be patience, everything will be fine.
  13. shahbaj alam
    open beta 32 is available on OnePlus website, download it
  14. pvtjoker25
    Roger that
  15. shahbaj alam
  16. pvtjoker25
    just ignore it[e]1f602[/e].. thanks i will download it.. appreciate the help[e]1f44d[/e]
    shahbaj alam likes this.
  17. JACK CITY
  18. Mr_Cyrox
    KitKat Jun 29, 2019
    pvtjoker25 likes this.
  19. pvtjoker25
  20. Gosahare
    Gosahare , Jun 29, 2019 :
    It's only me or you all have limited download speed from play store.
    Mine is fixed at 628 kbps while downloading apps, though I have 25mbps connection.
