155
OxygenOS Open Beta 35 for the OnePlus 5 and Open Beta 33 for OnePlus 5T
  1. kbszh123
    Gingerbread Aug 31, 2019
  2. Mr_Cyrox
    KitKat Aug 31, 2019
    Mr_Cyrox , Aug 31, 2019 :
    No one said that
    otto2 likes this.
  3. kbszh123
  4. Mr_Cyrox
    KitKat Aug 31, 2019
    I'd like you to provide a source because I seem to not believe your claim
    As far as I remember no one said that Q will be on stable first and/or only on it
    otto2 likes this.
  5. chawdau
    Cupcake Aug 31, 2019
  6. Waveform Modifier
    Marshmallow Aug 31, 2019
  7. Apraveen123
    Cupcake Sep 1, 2019
    Apraveen123 , Sep 1, 2019 :
    I have update to open beta 35, but my screen recording facility is not good. i am unable to access it. please suggest me a solution.
  8. Waveform Modifier
    Marshmallow Sep 1, 2019
    Waveform Modifier , Sep 1, 2019 :
    Get out of beta. There will be no further updates.
    otto2 and gotshoaib like this.
  9. gotshoaib
    Gingerbread Sep 3, 2019
    gotshoaib , Sep 3, 2019 :
    Any update tips to save myself from formatting data.
  10. Waveform Modifier
    Marshmallow Sep 3, 2019
    Waveform Modifier , Sep 3, 2019 :
    Maybe wait for stable to get further enough to see it as an update. But the safest way is to format. Less issues.
    otto2 likes this.
  11. gotshoaib
    Thanks
    Most likely will wait for newer build version update.
    I read somewhere format is required bcuz stable builds are older versions than beta. I guess updating to newer version stable update without format should be just fine.
  12. MarcoMicale
    Eclair Sep 3, 2019
  13. ichinisan
    Honeycomb Sep 3, 2019
    ichinisan , Sep 3, 2019 :
    if only you would have read the original post. it said this is the last beta..
    otto2 likes this.
  14. MarcoMicale
    Eclair Sep 3, 2019
  15. ViJaYaJiV
    Cupcake Sep 3, 2019
  16. praveenkumar789
    Cupcake Sep 3, 2019
  17. Aziz_Amin_Oneplus
    Jelly Bean Sep 3, 2019
    Aziz_Amin_Oneplus , Sep 3, 2019 :
    Please read the first post written by Manu J, you will get your answer.
    otto2 likes this.
  18. F_Amish_Shah_JBOy
    Cupcake Sep 4, 2019
  19. Waveform Modifier
    Marshmallow Sep 4, 2019
    otto2 likes this.
  20. mehulgupta462
    Gingerbread Sep 4, 2019
    mehulgupta462 , Sep 4, 2019 :
    pls oneplus provide a solution to ur open beta friends for reverting back to stable build without losing data
    its very difficult to set up device as it was earlier
