181
OxygenOS Open Beta 35 for the OnePlus 5 and Open Beta 33 for OnePlus 5T
  1. Waveform Modifier
    Marshmallow Nov 4, 2019
    Waveform Modifier , Nov 4, 2019 :
    Copy it to a computer or use any cloud services like Google Drive.
  2. Mr_Cyrox
    KitKat Nov 4, 2019
    Mr_Cyrox , Nov 4, 2019 :
    Or OnePlus Switch
    You know, the pre-installed app made for backups?
  3. jazzyjff
    Gingerbread Nov 5, 2019
    jazzyjff , Nov 5, 2019 :
    I was under the impression that when you flashed the update rom for the stable version it would wipe all local storage, hence making OnePlus Switch invalid as a way to backup the data. Is this not the case?
  4. Waveform Modifier
    Marshmallow Nov 6, 2019
    Waveform Modifier , Nov 6, 2019 :
    Copy out the backup, wipe, put it back in and restore.
    gotshoaib likes this.
  5. V1511372468702
    Froyo Nov 11, 2019
    V1511372468702 , Nov 11, 2019 :
    Is a full wipe required before or after rolling back to the stable OOS ? Is the rollback build in the first post still good for the purpose?
  6. Waveform Modifier
    Marshmallow Nov 11, 2019
    Waveform Modifier , Nov 11, 2019 :
    Yes
  7. sridiculous
    Gingerbread Nov 13, 2019
  8. Mr_Cyrox
    KitKat Nov 13, 2019
  9. sridiculous
    Gingerbread Nov 14, 2019
    sridiculous , via OnePlus 5 , Nov 14, 2019 :
    not sure, never used stock recovery, but would assume that it should still work, ymmv.
  10. Pierre02
    Honeycomb Nov 16, 2019
    Pierre02 , Nov 16, 2019 :
    Probably yes, but NOT on this beta channel. You'll have to be on latest Pie STABLE to install that beta
  11. dekmedina , via OnePlus 5T Midnight Black , Nov 16, 2019 :
    that's sad to hear. have so much files to backup if that's the case tho. need to buy a external hdd
  12. Waveform Modifier
    Marshmallow Nov 16, 2019
    Waveform Modifier , Nov 16, 2019 :
    You took on that risk when you installed the beta. Mooted point to complain about that now.
  13. dekmedina , via OnePlus 5T Midnight Black , Nov 16, 2019 :
    Don't be mean mate. Please respect others. Without beta tester we will not accomplish many things and sacrifices we have right now. It's not really a problem if they rollout Android 10 as a last update on Beta. Don't be rude to others mate. Does anyone loves you? Don't worry we the community are here for you. Slide me a message if you are having a issue with yourself. May God bless you.
    Iceman_KMY likes this.
  14. Pierre02
    Honeycomb Nov 18, 2019
    Pierre02 , Nov 18, 2019 :
    On your version you are not able to install any update. You won't receive OTAs anymore and you won't be able to install updates via TWRP or Local Upgrade without a wipe data. The Android 10 Beta will be a stable build not rolled out via OTA. For example, OP3 Pie Beta 1 was version 9.0.0, Beta 2 was 9.0.1 and the stable was 9.0.2
  15. iharshjjain
    Ice Cream Sandwich Nov 19, 2019
    iharshjjain , Nov 19, 2019 :
    No.
    as the Closed Beta Program has already been shut down.
  16. Waveform Modifier
    Marshmallow Nov 19, 2019
  17. sridhargade
    Cupcake Nov 20, 2019
  18. Waveform Modifier
    Marshmallow Nov 20, 2019
  19. sridhargade
