181
OxygenOS Open Beta 35 for the OnePlus 5 and Open Beta 33 for OnePlus 5T
  1. LimpWizard61
    Cupcake Mar 13, 2020
  2. Waveform Modifier
    Marshmallow Mar 13, 2020
    Waveform Modifier , Mar 13, 2020 :
    It is literally on page 1 of this thread. You were not looking too thoroughly.
    otto2 likes this.
  3. LimpWizard61
    LimpWizard61 , via OnePlus 5 , Mar 13, 2020 :
    I found this topic, in fact, I knew that I had to format the phone, but I wonder if it is possible to do this without clearing the phone’s memory?
  4. Waveform Modifier
    I believe someone already tried and ended up needing to wipe the phone. Why would you want to risk it otherwise anyways. It's almost like going from one ROM to another.
    otto2 likes this.
  5. LimpWizard61
    Unfortunately, the hands do not get to the point, it's too long a process :(
  6. Waveform Modifier
    Too long of a process to backup? You should backup all your stuff regardless if you are doing this or not. Also, when you flash the beta, you should of known you have to do this one day. The warning is there in every single beta thread. You are not going to get any sympathy here.
  7. LimpWizard61
    Maybe I just don’t know how the backup works, I have a lot of photos, videos, and different caches. Please tell me if there is a program on the computer to copy all this?
  8. Waveform Modifier
    Google it. It's not that hard.
    otto2 likes this.
  9. LimpWizard61
  10. hassan5482
    Froyo Mar 16, 2020
  11. jaivalar
    Eclair Mar 25, 2020
  12. Waveform Modifier
    Marshmallow Mar 25, 2020
    otto2 likes this.
  13. B_Wrath
    Nougat Mar 25, 2020
    B_Wrath , Mar 25, 2020 :
    All beta related queries must be done on the beta thread.
    That is expected out of any competent beta tester.
    Don't create redundant threads.
    otto2 and Waveform Modifier like this.
  14. Cervantes
    Lollipop Moderator Mar 25, 2020
    Cervantes , Mar 25, 2020 :
    Hi
    the beta thread is a question and comment thread
    a thread will open with the announcement of the update
    Please, read the first post
    Use the search engine before opening a new thread
    Thread merged
    otto2 likes this.
  15. jaivalar
    Eclair Mar 25, 2020
    jaivalar , Mar 25, 2020 :
    I have factory reset all data
    but still unable to update one plus 5
    9.0.11
    went to recovery mode
    wipe data and cache ,Then went to
    Install from internal storage
    installed ota incremental update but not getting updated
  16. Waveform Modifier
    Waveform Modifier , Mar 25, 2020 :
    You can't go back to stable from an incremental update file. You will need the full update file.
    otto2 likes this.
  17. Mask_RWX
    Cupcake Mar 27, 2020
    Mask_RWX , Mar 27, 2020 :
    hi, where can i find the exact step-by-step guide beta35 to 9.011? im noob on this :\
  18. Waveform Modifier
    Marshmallow Mar 27, 2020
    Waveform Modifier , Mar 27, 2020 :
    You can use search. Had been typed out many times before
  19. G1519005640596
    Cupcake Mar 30, 2020
    G1519005640596 , Mar 30, 2020 :
    Can we at least get security update for beta and battery is draining very fast. can we have fix for it in beta update
  20. G.Andrea
    Froyo Mar 30, 2020
    G.Andrea , via OnePlus 5T , Mar 30, 2020 :
    You'll not receive any update for Oxygen OS beta since it's discontinued, if you want to get "latest" security updates you have to switch to the stable channel. It's not flawless but at least the security patches are coming.
