190
OxygenOS Open Beta 4 for OnePlus 6
  1. staycalm
    Froyo Oct 1, 2018
    staycalm , Oct 1, 2018 :
    Is anyone else experiencing major battery drains? I have to charge my phone twice in a day. I've got 26% drained in 55 minutes without any gaming
  2. Deactivated User
    Oct 1, 2018
    horvath.patrick and Artemus. like this.
  3. Gary S
    Froyo Oct 1, 2018
    Gary S , Oct 1, 2018 :
    Got beta 4 this morning. To be honest, I don't really notice any difference. No bugs to report and things are running well.
    Pretty normal Sunday and my battery is at 63 percent at the end of the day.
  4. rkdugalad
    Froyo Oct 1, 2018
    rkdugalad , Oct 1, 2018 :
    that's for only beta tester bro... no official OTA updates
  5. mh_allye
    Eclair Oct 1, 2018
    mh_allye , Oct 1, 2018 :
    how's the playstore on beta 4? still not working?
    And can I move to beta from stable pie through system local upgrade?
    thanks for your kindness.
  6. B_Wrath
    Nougat Oct 1, 2018
    B_Wrath , Oct 1, 2018 :
    Try using colorful theme or light theme... Somehow in few cases, dark theme leads to force closing of phone app...
  7. disChapo
    Cupcake Oct 1, 2018
    disChapo , Oct 1, 2018 :
    Is it possible for the addition of automatic dark mode at night for a future release? Would make using it early morning or late at night much better.
  8. Artemus.
    Community Hero 2020 Oct 1, 2018
    Artemus. , Oct 1, 2018 :
    You can probably achieve this with something like Tasker or IFTTT (your mileage may vary). Don't quote me on that though.
  9. gubro
    KitKat Oct 1, 2018
    gubro , Oct 1, 2018 :
    Who said it was not working?
  10. rajeshkumar_r
    Froyo Oct 1, 2018
    rajeshkumar_r , Oct 1, 2018 :
    Yes I'm facing battery drain even on stand by mode and SOT has reduced too much than before.
    staycalm likes this.
  11. rajeshkumar_r
    Froyo Oct 1, 2018
    Anyone facing issues with displaying network speed? Sometimes it displays on notch right side and some times it displays inside the quick settings automatically. Is it normal or any issue with this beta upgrade?
  12. B_Wrath
    Nougat Oct 1, 2018
    See which app hogs the battery the most and Uninstall it ..
  13. rjalkekar
    Froyo Oct 1, 2018
    rjalkekar , Oct 1, 2018 :
    I am facing some weired issue with this update, when I call from my mobile, I can here other person picking the call(dial tone ends) but it takes some 5 to 10 seconds to reflect in my mobile and then the seconds count starts on the screen. after that only I can here voice from other end. this is the situation with all calls going from my end.
    I am not sure this is the bug, but there will be some 5 to10 seconds delay during the call initiation.
    thanks in advance for your support.
  14. saifkaleem
    Cupcake Oct 1, 2018
    saifkaleem , Oct 1, 2018 :
    Im running open beta 4...can i go back to stable PIE?
    Someone watching plzz tell how to go back to pie from open beta 4!
  15. B_Wrath
    Nougat Oct 1, 2018
    You can go back by searching the forum and reading the solution...
  16. rjalkekar
    Froyo Oct 1, 2018
    Hey U can go back by choosing stable update manually which we received two weeks before. but take backup of ur data. any downgrade will wipe data and hard reset to previous version.
    njoi flashing :)
    B_Wrath likes this.
  17. G_Amit_Tiwari_zcOu
    Gingerbread Oct 1, 2018
  18. saifkaleem
    Cupcake Oct 1, 2018
    You mean... I have to download the official pie update file and install it?... Thanks for replying sir[e]1f64f[/e]
  19. rjalkekar
    Froyo Oct 1, 2018
    Hey,
    Try uninstalling and reinstalling the outlook app. even I faced some issue last time... it got fixed later after reinstalling...
    Hope it helps... cheers :)
  20. rjalkekar
    Froyo Oct 1, 2018
    yes Sir...
    that's the only way of solving your needs... even I did same to move back from OB 3 to stable version..
    saifkaleem likes this.
