190
OxygenOS Open Beta 4 for OnePlus 6
  1. saifkaleem
    Cupcake Oct 1, 2018
    saifkaleem , Oct 1, 2018 :
    Thanks sir
    rjalkekar likes this.
  2. longtime_user
    Froyo Oct 1, 2018
  3. zaimuf
    Cupcake Oct 1, 2018
    zaimuf , Oct 1, 2018 :
    I cleaned flashed open beta 1 and then updated via Ota to open beta 4, did it twice to confirm that playstore download progress doesn't show under notifications, one the app has downloaded or has been updated only then a notification appears, progress bar doesn't appear while the app is being downloaded or updated, I explicitly saw it was working on ob1 and stopped after update to ob4
    longtime_user likes this.
  4. saifkaleem
    Cupcake Oct 1, 2018
    It doesn't show until u pull down the notification bar
  5. zaimuf
    Cupcake Oct 1, 2018
    it doesn't show at all.
  6. saifkaleem
    Cupcake Oct 1, 2018
  7. zaimuf
    Cupcake Oct 1, 2018
    I completely formatted my internal and reinstalled oreo and updated back to pie, I don't think there's anything else left to do, and like I said on ob1 the notification shows, after update to ob4 as soon as I reboot it stops showing
  8. AspirinE313
    Froyo Oct 1, 2018
  9. zaimuf
    Cupcake Oct 1, 2018
    device is certified and safety net passes so it should work
  10. AspirinE313
    Froyo Oct 1, 2018
  11. YellowClaw
    Honeycomb Oct 1, 2018
    YellowClaw , Oct 1, 2018 :
    happens on my phone too.
  12. Q1537948917331
    Cupcake Oct 1, 2018
  13. F_Shahryar_Shahryari_rQa
    Froyo Oct 1, 2018
  14. B_Wrath
    Marshmallow Oct 1, 2018
    B_Wrath , Oct 1, 2018 :
    Will what work???
  15. B_Wrath
    If you have turned on auto time zone in clock, it is bound to change...
  16. Q1537948917331
    Cupcake Oct 1, 2018
    Q1537948917331 , Oct 1, 2018 :
    shall I use beta4 zip from mobile instead of laptop??
  17. B_Wrath
    Yes you can...
    Q1537948917331 likes this.
  18. AbhishekD95
    Cupcake Oct 1, 2018
  19. 8686595952
    Donut Oct 1, 2018
    8686595952 , Oct 1, 2018 :
    google play services takes more battery after beta 4 update.... more than screen
  20. rjalkekar
    Froyo Oct 1, 2018
