190
OxygenOS Open Beta 4 for OnePlus 6
  1. thechicken65
    Honeycomb Sep 29, 2018
    thechicken65 , Sep 29, 2018 :
    Ah finally! I kept visiting the community app just to check for the latest beta release. Weekend gonna be good,!
    #41
    farazshafi likes this.
  2. V1535045503861
    Cupcake Sep 29, 2018
    #42
  3. B_Wrath
    Marshmallow Sep 29, 2018
    #43
    Aks41179 likes this.
  4. B_Wrath
    B_Wrath , Sep 29, 2018 :
    There is nothing to fix in the brightness... What is the issue you have ??
    #44
    getrealtunes likes this.
  5. B_Wrath
    You won't get stable updates... You'll get beta updates... The stable 9 zip is on the downloads page... You can install it if you want to go back to stable from beta..
    #45
  6. B_Wrath
    Yes... It shows certified... And Google pay has been working since the day stable pie released...
    #46
    W1534280953342 and freshgiammi like this.
  7. B_Wrath
    Did you try a restart?? If you did, try a network reset...
    #47
    alonroz likes this.
  8. Aivaras1334
    Eclair Sep 29, 2018
    Aivaras1334 , Sep 29, 2018 :
    Its very low. I have to be atleast at 70-80% of brightness for same light when in Oreo i needed about 20-30%. In daylight its almost imposiible to see something
    #48
  9. B_Wrath
    Which version of the OS do you use ??
    #49
  10. alonroz
    Donut Sep 29, 2018
    alonroz , Sep 29, 2018 :
    Tried both. Does not help. 4G data works perfectly, just can't turn on the Wifi at all. Switch keeps going back to Off mode.
    #50
  11. B_Wrath
    Read this... Please do a simple search before posting... This was answered 1000s of times in this forum... And the brightness was never reduced... The 100% is same as it was in oreo...
    #51
  12. Richard_Drinkwater
    Eclair Sep 29, 2018
    Richard_Drinkwater , Sep 29, 2018 :
    Yes , device is certified and G Pay also works.
    #52
    B_Wrath and freshgiammi like this.
  13. Aivaras1334
    Eclair Sep 29, 2018
    Yes, 100% just like it was in Oreo. but until 70% its much darker than it was before
    #53
  14. B_Wrath
    Do you have the smart wifi switcher turned on in your wifi preferences???
    #54
    alonroz likes this.
  15. B_Wrath
    Did you read my reply properly??
    It is because the scale is no more linear... It's logarithmic... Gives more control over the lower band...
    Once again... Please read completely... Also read the thread linked in my reply...
    #55
    getrealtunes and amitdate like this.
  16. Viper858
    Donut Sep 29, 2018
    Viper858 , Sep 29, 2018 :
    You have to downgrade to Stable Version of Oreo than you csn Flash with ota to Stable Pie
    #56
  17. RahuLSanjayPatiL
    Eclair Sep 29, 2018
    RahuLSanjayPatiL , Sep 29, 2018 :
    Hey, I have a query, just for my knowledge :)
    Why this 4th version Open Beta is released, as already the stable version was released for OP6 right after 3rd one ?
    Thanks in advance :)
    #57
  18. farazshafi
    Froyo Sep 29, 2018
    farazshafi , Sep 29, 2018 :
    santino86
    still only way to install stable pie from beta is to rollback to android 8? is there a other way upcoming way?​
    you can use the fastboot method if you want.
    but i think you need unlocked bootloader for that. I am not sure though.. check with someone.
    #58
  19. B_Wrath
    Open beta has always been continued even with stable released... Has been like that since OP3 days...
    #59
  20. alonroz
    Donut Sep 29, 2018
    It was disabled when the issue started. Tried both ways, with it on and off. No luck...
    Now trying to flash the new beta again, will update here.
    #60
    B_Wrath likes this.
