190
OxygenOS Open Beta 4 for OnePlus 6
  1. saifkaleem
    Cupcake Oct 1, 2018
    saifkaleem , Oct 1, 2018 :
    I too face the same issue... Sometimes i coudnt call from sim 1...i need to restart the phone... Fed up it
    karthick.coolblue likes this.
  2. longtime_user
    Froyo Oct 1, 2018
    longtime_user , Oct 1, 2018 :
    Countrywide call drop issues in India. I don't think it has anything to do with ob4
    B_Wrath likes this.
  3. saifkaleem
    Cupcake Oct 1, 2018
    Y not in my samsung galaxy A9 pro? ... Its happening only in my one plus 6
  4. karthick.coolblue
    Eclair Oct 1, 2018
    karthick.coolblue , Oct 1, 2018 :
    i use Airtel sim in slot 1... sim 2 i use jio... that works just fine...
  5. Ryanf78
    Gingerbread Oct 1, 2018
    Ryanf78 , Oct 1, 2018 :
    you must enable that feature in the settings menu once you update your phone to latest beta. it's not turned on by default.
  6. Gremlin247
    Froyo Oct 1, 2018
  7. Ryanf78
    why not, either download oxygen updater from the Play store. or you can get software from OnePlus own website. both have instantly access to pie software. Beta 4 or Stable build. good luck.
    B_Wrath likes this.
  8. Gremlin247
    Froyo Oct 1, 2018
    Gremlin247 , Oct 1, 2018 :
    I want to get the stable build but I haven't had the notification to update yet
  9. Ryanf78
    like I said go to store and get oxygen updater app. that will let you download both stable or beta. if you need any more help let me know.
  10. Gremlin247
    Froyo Oct 1, 2018
    do I need to backup my data before using it
  11. amrutk
    Cupcake Oct 1, 2018
    amrutk , Oct 1, 2018 :
    Post the new update, my finger print reader is slow. Is that an issue others r facing too?
    longtime_user likes this.
  12. Ryanf78
    you don't have to do a back up. your data will not be erased. but always a good idea to back up. just in case. your call.
  13. Gremlin247
    Froyo Oct 1, 2018
    I just downloaded pie thanks a lot man
  14. Braggus
    Eclair Oct 1, 2018
  15. Ryanf78
    your welcome. enjoy! honestly I think that beta 4 is better/more stable than the stable build IMO. but if you do decide to go for beta 4 and then want to go back to stable build. you must wipe your phone data and start over from stable Oreo 8.1 build. than u can go to pie stable. I little bit of a pain. but I'm on beta 4. and really like it. all apps work fine.
  16. Gremlin247
    Froyo Oct 1, 2018
    I got the stable version instead of beta
    Ryanf78 likes this.
  17. YellowClaw
    Honeycomb Oct 1, 2018
  18. rajeshkumar_r
    Froyo Oct 1, 2018
    rajeshkumar_r , Oct 1, 2018 :
    No third party apps are causing battery drain, I bought this device two days ago and facing battery drain issue from start. Not sure it's due to Android Phone upgrade or device fault.
  19. B_Wrath
    Nougat Oct 1, 2018
    B_Wrath , Oct 1, 2018 :
    Post a screenshot of your battery stats ..
  20. rajeshkumar_r
    Froyo Oct 1, 2018
    Please check..
